Even Distance Divider Tool
7,567
157
25
About: Engineer + power tools + left unsupervised = Makerneer! Content may contain affiliate links.
Ruh-ruh-ruh Remix!
So sometimes I want to be lazy and don't want to math when laying out a project. Judge away, but you know you've been there too...
An then... I found out there is a tool that can evenly space things 4 you! I must have one of these...
Woah, they cost how much? That's ridiculous... They don't look that hard to build, it's like 3 different parts and some bolts?! I'd even bet someone else has already done it. To the internets!
Score! Turns out Mikeasaurus has an Instructable for a similar version of the tool I'm after! https://www.instructables.com/id/Equidistant-Layou...
So I built one (Thanks Mike!).
And then I broke it (I know, I know, this is why I can't have nice things...)
Getting the rivet tension right is tough. That's my excuse and I'm sticking to it.
However, it was a really useful tool to have before I broke it. I still want one! So I took the basic geometry from Mike's tool and made my own, replacing the rivets with chicago screws.
OK, intro over, onto step two!
Teacher Notes
Step 1: Tools, Materials, Safety Stuff
Tools
1) Laser cutter
2) Digital calipers
3) Computer with design programs (I used Fusion 360 and Inkscape)
4) Some way to hold the material to the laser cutter bed (I use magnets covered in tape)
5) Screw driver
6) Medium grit sandpaper (Side tangent - Is sandpaper a tool or material or both?!)
7) Hobby knife or razor knife
Materials
1) Cardboard (for the prototypes)
2) 1/8" plywood or MDF (Make sure it's laser safe. 3mm thick wood works too)
3) Polyurethane spray (Not required, but protects the wood and gives it a nice finished look)
4) Chicago screws (Common in leather working)
1/4" (6-7mm) length for the 2 part stack
3/8" (9-10mm) length for the 3 part stack
5) Blue Loctite (I like blue over red Loctite for this in case we need to adjust the tension or change the design)
Safety stuff
1) Laser glasses (Or whatever safety precautions the laser you're using requires)
2) Respirator (or a well ventilated area to paint)
Use the right filter cartridges for painting with the polyurethane.
I also usually use a prefilter, but you also need a retainer to hold it onto the cartridge.
You can get a combo cartridge and filter.
3) Patience (This is tough for me sometimes, as the project gets closer to being finished I want to work faster to see the final product! This is usually when I start making stupid mistakes... )
Step 2: Laaayyyyssirrr.
In case you were wondering, that is the official metric spelling of "laser." Trust me, I'm an engineer...
Right, time to burninate and iterate!
Version 1 was cut using cardboard. It mostly worked... The chicago screws fit correctly and the tool articulation was smooth, but the tool wouldn't close all the way due to the chicago screws hitting the indent on the pointer leg.
V2 eliminated the clash, but the divider body ended up a little weaker than I'd like in the indent area.
V3 beefed everything up a little bit by making the legs wider.
V4 accounted for me not adjusting the indent when I made the legs wider in V3...
V4 was successfully tested without cutting a full set of components.
V5 added some personalization with the gear wheel option for the handle area.
V6 cleaned up the file and nested the parts neatly for laser cutting.
This is the version was fully assembled to test.
(V6 is not the final version, see next step for digital file)
Proof of concept complete, time to graduate from cardboard to wood!
Step 3: Dexterity Test, AKA Tool Assembly
I used 1/8" laser safe MDF for the first wood prototype.
Assembly is "fiddly" the first time, but you get the hang of it pretty quick.
  1. Start with the pointer legs on the bottom.
  2. Attach a connector piece to the top hole of one pointer leg and the slot of the next leg
  3. Stack another connector piece on the top, lining up the slot of the first divider leg and the top hole of the next divider.
  4. Insert chicago screws into all the holes.
  5. Loctite the chicago screws once you're happy with everything. This will keep them from loosening as you open and close the tool. (A dab will do, go easy on the loctite!)
I've also included pictures of the layout part of the assembly process, I know pictures help me more than text sometimes.
Overall, it worked. It was just a little loose. So I fired up Fusion 360 again and made version 7.
Version 7 changed the holes to net fit (exactly the same size as the chicago screw shaft) and I undersized the slot by .15mm (Yes, .15mm, not a typo. And yes, it made a noticeable difference). Version 7 is where you might need to use sandpaper or the razor to open up the holes if you can't get the chicago screw to fit.
All those changes tightened things up, but it still just wasn't quite right. Check the last picture in this step to see what I mean.
So... yep, that means another step in this instructable!
Step 4: Redirect, Remix the Remix
Ever had one of those projects that you started redesigning before you even finished?
Right, of course you have. THIS is why everything takes so much longer than it should!
Soooo.... yeah...The tool works, but even after removing all the clearance in the holes and slots there's still just a bit of tolerance I can't seem to get rid of with the sliding design. And... I made the mistake of borrowing a professional version of this tool from a friend to see how it works. So this "tolerance stackup" is enough to annoy me now that I know the "real" version works better. Wiferneer also ran across a metal commercial sliding style divider tool at a sewing expo about this time and we saw the same tolerance stackup with the commercial version that is in our homebrew version.
Sigh. Back to the drawing board...
The tool I borrowed works well. There isn't noticeable or measurable (with a tape measure) slack. The main difference I see is that it uses a pivioting motion on the pointer legs instead of a sliding motion.
With this observation, I changed directions from a sliding style divider tool to a pivoting style divider tool. This doesn't look as neat, isn't as fun to use, isn't as clean to mark intervals since the tip is canted - but it removed a little more tolerance and it reduced the number of parts to assemble so we'll call it a win.
Attached to this step is the re-remix V8, a pivoting style equal distance divider tool.
This is the one I'm personally using in my shop.
Assembly of V8 is easier than V7, there's only two layers to stack and that means there's also only one size of chicago screw needed. Basically criss-cross a pointer leg and a connector leg to assemble. Insert a chicago screw and then Loctite the screws when you're done. I forgot to take pictures during the assembly so unfortunately we'll have to use the picture of the tool expanded for the assembly reference.
Step 5: Measure All the Things
It works!
OK, I know you have questions, so here's some questions I asked myself while working on this re-mix.
1) Self - Why can't the tip of the divider just be a normal triangle? Answer - Dear Self, The tip has a straight edge so you can draw a straight line to mark on your workpiece. Duh...
1a) In the pivoting version this is less of a thing since the tips angle sideways instead of slide up and down.
2) (OK, I can't do third person anymore...) Why are there scallops on the divider leg of the sliding version but not on the other legs? Answer - The chicago screws need to be able to nest into this piece in order to fully collapse the tool. Checkout the picture.
3) Do you think this will be as accurate as the commercial versions? Answer - Probably not. This version is made of wood and there has to be some "tolerance" to allow the screws to rotate. However, I'd bet it's just as accurate as using a tape measure to do the same layout job and it's faster.
4) You list polyurethane in the materials section, but this tool doesn't look finished? What gives? Answer - I need to stop using it for a couple days so I can take it apart and put a coat of poly on it to make it last longer!
5) Why is the metal version so much taller? Answer - Please proceed directly to the next step. Do not pass go.
Step 6: Further Down the Rabbit Hole...
Answering the question 5 from the last step:
While making these tools it became evident that the longer/taller legs on the commercial version serves to force the center of the tool to open at the same time as the outside. This is important since it eliminates even more "tolerance stackup" and makes the tool more accurate.
Yep, that mean a re-re-remix.
Someday...
For now I can live with V8 (vroom!) so V9 might have to wait until the next instructables contest!
Or, maybe you, person reading this, will run with it and make version 9?!?! I've attached the Fusion 360 file to this step in case you want to play with the geometry (Thanks mevans12 for requesting it!).
OK, that's it for today. Thanks for reading along with me as I learned how this divider tool worked and please consider voting for this Instructable in the Remix Contest!
Remix Contest
Second Prize in the
Remix Contest
  • Indoor Lighting Contest
  • Metal Contest
    Metal Contest
  • Make It Fly Challenge
25 Discussions
Diomar
Question 8 weeks ago on Step 4
Hello friend, thank you very much for sharing your ideas, I wanted to know how to export V7 and V8 full scale drawings for printing, as I tried to print them but they are incomplete. I do not own a laser cut and I plan to build it from metal plates with the tools I have even being more works. thanks again.
1 answer
MakerneerDiomar
Reply 8 weeks ago
Hi,
Thanks for your comment!
The files for this instructable are in DXF format. What software are you using to print the files?
If you are looking for a program to use, Inkscape is a great product that's free to use and download. https://inkscape.org/
If you want to convert the file to a different format, I have had good success with this file converter. https://convertio.co/
PaulNaude01
5 months ago
This is genius! Simplicity squared. How many times did I have to do the mark, measure, mark, measure process just to mess it up along the way in any case?
MakerneerPaulNaude01
Reply 5 months ago
I know right! I felt the same way when I found out this tool existed.
tonyio
5 months ago
Excellent! I love that you continued making it better and better and better… ;)
SIM1T2
5 months ago
Impressive. Could you consider supports for pencils/pen cartridges/xacto blades on a ver. 2.0?
MakerneerSIM1T2
Reply 5 months ago
Interesting idea, it would be handy to have a pencil attached to it. I'm not sure what that would look like yet, but it would be fun to play around with the design sometime!
Eh Lie Us!
5 months ago
Good night, Irene. I could have used something like this so many times in my life. Math be gone!! Well not entirely but wow, this is a time saver. Thanks for sharing.
Waste Of Space
5 months ago
I see that in your instructions, you say that you use a magnet to hold the material in position. Why?
There are no lateral cutting forces involved with a laser and little chance of the material moving unless you move it yourself.
Apart from that, nice instructable. :)
MakerneerWaste Of Space
Reply 5 months ago
Great question, thanks for your comment!
I use magnets for two reasons.
1) My laser (Glowforge) uses an air assist fan behind the laser head to help evacuate smoke and keep the flame down while cutting. The magnets help make sure nothing gets moved accidentally when the fan starts blowing.
2) The flatter /closer to the programmed focal point I can keep the material while cutting the better things go. Some boards start a little warpped, some things (cardboard and leather in my experience) like to warp when they get hot. The magnets are a band aid to try and overcome these issues while cutting.
Hope that answered your question!
mikeasaurus
5 months ago
Nicely done! I think Chicago screws are the way to go, as i also has a tough time getting the fit right with rivets. I think I'll make my next divider tool more like yours! :)
MakerneerDavidF15
Reply 5 months ago
Thank you for sharing that Instructable! I hadn't seen that method before, I'm happy to add that trick to my arsenal.
I do still like this tool since I can use it on the fly without needing a ruler.
JAMESM466
5 months ago
I've wanted on of these for years, after seeing a similar item in use to lay out rivets on a car project. I do not have any shop automation, so this will be a by-hand only job. 1/8" aluminum stock looks like a viable material.
MakerneerJAMESM466
Reply 5 months ago
Now that I have one, it's one of those tools I can't believe I went this long without! 1/8" aluminum will probably work great and look good!
midbay
5 months ago
Thanks for an excellent write up. I may try lasering this in acrylic to see if it's more structurally stable dimensionally.
