Example of Locker With Arduino Matrix Keypad 4x4
About: Interest in PUNK/HARDCORE/METAL/HIGHLAND BAGPIPE
2 ways to manage a 16 pushbuttons keypad with a minimum of pins.
Teacher Notes
Step 1: Intro
I recently worked on a way to manage a 4x4 touch keypad matrix connected to an Arduino clone. The set points were:
-to use only 4+1 pins instead of 8 pins on the atmega328p
-to add a LCD Display 4x20 CHAR link via I2C (2 pins)
-to control digital and analog outputs.
So, having a lot of things to control with a sin amount of I/O.
Step 2: Things to Use:
I bought a LCD display 4x20 characters and an I2C module adaptator to connect the display with SDA (A4) and SCL (A5) pins on my arduino clone.
I use the famous and now obsolete MM74C922N: a 8 to 4 ways converter fit to the 4x4 matrix keypad.
I created a clone of the arduino based on the atmega328p and programmed via an HE10 connector (SPI bus) and an USBasp cable.
Step 3: Schematic and the Board:
The board is made of:
-the LCD keypad only use with Arduino IDE, not possible with LDmicro (Ladder programming)
-the MM74C922N board: 16 pushbuttons coded on 16 binary values on 4 bits DCBA. When a button is pressed: the blue led lights on and a value appears on DCBA (A is the LSB). When a button is released: the blue led lights off and the value is reset to zero on DCBA.
-the Arduino atmega238p clone board.
Step 4: Using LDmicro With Ladder Programming:
The code to enter is made of 4 values among 16 keypressed values so 16x16x16x16 combinations.
Once you draw the SFC, you have then to translate it into LADDER with the method given in one of my
instructables :
https://www.instructables.com/id/Arduino-tomation-...
Once typed, compile it as xxxx.hex and then download it with KHAZAMA downloader.
The LCD display cannot be programed on LDmicro.
I give LDmicro zip with the sketch SERRURE.id in it and the KHAZAMA downloader.
Step 5: Using Arduino IDE 1.8.x With Mightycore and SMlib:
I translate the SFC into a state machine. Then I used Arduino IDE with the Mightycore and SM library inside.
I display message like: ERROR, WAITING, UNLOCK, state reached, value of the keypressed on the LCD diplay.
I give you the sketch and the SM lib. For Mightycore look at this:
https://www.instructables.com/id/Arduino-18x-Clone...
Step 6: To Conclude:
These are two ways to manage the 16 keypad and it took me several hours to find the good sequence but now it works fine. You must respect these steps:
-1 detect a keypressed on a rising edge of the DA pin
-2 read the value generated on DCBA and compare to the good one
Unless it will certainly not work.
Thanks to all interesting tutorial over the net.
    • Indoor Lighting Contest
    • Make It Fly Challenge
    • Growing Beyond Earth Maker Contest
