Experiments in Creating Graphene
28
Introduction: Experiments in Creating Graphene
Graphene is made of a single layer of carbon atoms that are bonded together in a repeating pattern of hexagons. It is so thin that it is actually considered two dimensional. Graphene’s flat honeycomb pattern grants it many unusual characteristics. In this instructable, we share our experiences of creating Graphene.
Supplies:
  1. Microscope Slides
  2. Cardboard
  3. Kapton Tape
  4. Multimeter
  5. Laser Cutting Machine
Teacher Notes
Step 1: Preparing the Microscope Slides
The Kapton Tape is stuck on a microscope slide with a piece of cardboard for support.
Step 2: Laser Etching the Kapton Tape to Produce Graphene
We use a 130W TroTec Laser Cutting machine to etch the surface of the Kapton Tape to produce Graphene.
A power of 1.25W and a speed of 0.25 was used in our settings on the TroTec.
Note: The Power and Speed settings may vary with different laser machines and tapes.
Step 3: Testing for Graphene
Graphene is a conductive material. One way to find out whether the etching process produced Graphene is to check for its conductivity using a multimeter.
Our experiments showed a resistance ranging between 70 Ohms to 90 Ohms for the Graphene that was produced with our process.
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Fix It Contest
      Fix It Contest
    2 Discussions
    tytower
    tytower
    15 days ago
    So could this technique be used to actually print circuits on the Kaptan tape?
    Can the layer be thickened up to decrease resistance?
    Would it be possible to join a surface mount component between the lines of graphene with perhaps a conductive glue ?
    Also what is IN the kaptan tape that produces graphene by applying heat?
    audreyobscura
    audreyobscura
    17 days ago
    Cool! Thanks for sharing your experiment!
