Fake Fordite Paper Ring
4,553
89
8
Introduction: Fake Fordite Paper Ring
About: What about me???? I don´t know what the h ask me anything but don´t expect a serious answer but for real If you want to connect do it
What do you need, not much.
-old paper
-a Knife, scissors maybe
-Sandpaper
-CA- Glue (about 2gramms (In Germany you can buy 5x2g at wolworth for 1€))
-Backing paper (or something that CA-Glue doesn´t stick to as much) -Thats it, so don´t be a maybe or something
Teacher Notes
Step 1: Preperation
Cut strips of Paper to the width
you want the ring to be. Use Paper in diffrent collors that are -perfarably – colored throu and throu.
Find a rod that is about 0,2-0,3mm bigger than the ring inner diameter later needs to be. If you can find one use one that is a little under and build the size up, by wrapping it in tape or something
Now attach the backing paper with string or tape or don´t just makes it a little more practical
Step 2: Wraping the Paper
Wrap the first layer around and
then glue it together (I mean... its kinda obvious, but here you can determine the Inner color of the Ring)
You can now Wrap a few more strips and continuesly glueing it.
What kind of pattern do you want? THINK...think a little more. Think of the form of the finished ring and think of the Layers that intersect the surface. I just put one/two Bump in there, but you can also make a curved bump or maybe twist a few layers of paper and glue them on the surface. This is the point where you can make your ring unique and be creative
now build up to the thickness of the ring till you are contend with it.
Step 3: Shaping
Just shape the Ring with the tools
that you have (a knife is good enougth buuuuuut....)
then sand it to a „nice“ finish
Step 4: CA-extravaganza
Put a thin Layer of CA glue on
there let it dry and but the next Layer on (I do the Inside and outside alternating so I have something to hold on to)
Step 5: Sand and Polish
you know what to do
Step 6: The End
If someone accually does that or is
inspierd by that, let me know I reallly want to see If you use Instagramm tag me @astjaeger otherwise send me a message here or a commet, whatever... Email me if you want Astjaeger@gmail.com... send me nudes also and tell me about my nigarian unkle that died...
Colors of the Rainbow Contest
Be the First to Share
    • Sculpting Challenge
      Sculpting Challenge
    • Heart Contest
      Heart Contest
    • Fiber Arts Contest
      Fiber Arts Contest
    8 Discussions
    AustinR52
    AustinR52
    8 days ago
    I am about to attempt it right now but I think ima use CA glue for the first then I'm going to use clear fingernail polish hardener as my outside coats cuz it tends to polish and look better on finished projects and if it ever fades jus aply more clear nail polish and u don't have to spend as much time shining it
    Popd58
    Popd58
    5 months ago
    Absolutely brilliantly gorgeous and v clever
    I Def will attempt .....eventually....once finished my thread and bead key fob collection ..trying to get off the ground with it as an income as Ill health robbed me of my ability to be a reliable SEN TA
    Thanks for sharing
    Kwarseck
    Kwarseck
    10 months ago
    What is CA glue?
    jessyratfink
    jessyratfink
    Best Answer 10 months ago
    Cyanoacrylate or super glue!
    Owlherder
    Owlherder
    10 months ago
    Love this. I'm contemplating how I would make earrings with this method. Seems it would work. Maybe tack to a board and layer to desired thickness flat instead of circular.
    Astjaeger
    Astjaeger
    Reply 10 months ago
    sure that would wörk as well. Maybe a "Wave" isn't that nessecary when you do that but I would just try. I am for it.
    Arbormakes
    Arbormakes
    10 months ago
    This is beautiful!
