Introduction: Fantasy Glowing World
This instructable is dedicated to make a little fantasy glowing world from anything around you using some simple materials with simple tools after finishing your art you can decorate your own room or give it as presents to anyone you want to put a smile on his/her face
Step 1: MOLDING COUNTENANCE
Using clay (in this case white clay), mold a cube in 3x3x3 cm dimensions
Then cut another cube inside that first cube in 2,5 x 2,5 x 2,5 cm dimensions just like shown on the pictures
Step 2: CREATING ENVIRONMENT AND COLORING
Using that little cube from the previous step add environment as rocks water ways
after that color your countenance with acrylic paint without using water 'cause clay is already wet, leaving our fantastic glowing water way raw
Step 3: FINISHING WITH PHOSPHORUS !!!
By stirring blue and white phosphorus gel we create water variety the blue will glow blue while the white will glow green
apply the new formula on your countenance a water fall or a glowing path, to show love do not forget details (details are everything) like water splash and foam or physical logic like gravity
before seeing your results charge the whole thing under the light
Step 4: ENJOY YOUR RESULT
As other TIPS use the blue phosphorus gel to draw stars or galaxy on the roof or in the walls
or draw glowing post cards
Make it Glow Contest
