Fast & Easy Coin Cleaning
Introduction: Fast & Easy Coin Cleaning
This Instructable will show you a fast & easy way to clean coins.
Materials Needed:
  • Dirty coins
  • Electric Oscillating toothbrush
  • Baking Soda (Sodium Bicarbonate)
  • Lemon juice or white vinegar (optional for soaking)
  • Plastic container - large enough for all coins (optional for soaking)
  • small plastic container - to hold the baking soda
  • Paper towel or cloth (for drying)
Step 1: Soak Dirty Coins
This step is optional but does help in making it easier to remove the dirt / grime.
  1. Place dirty coins in plastic container
  2. Pour lemon juice (or white vinegar) into container just enough to cover the top of the coins
  3. Let soak for ~1 hr swirling solution every 15 minutes
Step 2: Scrubbing Dirty Coins
  1. Remove coins from soaking solution
  2. Pour some baking soda into the small plastic container
  3. Wet the tip of the electronic toothbrush and dip into the baking soda, so there is a paste consistency on the toothbrush head.
  4. Hold a coin between your fingers & turn on the toothbrush to clean each coin using the fast oscillations of the electronic toothbrush.
  5. Rinse off the coins & place on paper towel (or cloth) to dry
  6. Repeat 3 - 5 as needed for each coin.
First Time Author
First Time Author
Be the First to Share
    • Lighting Challenge
      Lighting Challenge
    • Puzzles Speed Challenge
    5 Discussions
    lbrewer42
    lbrewer42
    1 year ago
    If a coin has surface metal removed in any way (like wiping with a kleenex which will scratch it), the the valu eof the coin is greatly reduced to a collector.
    Problem: There are common date coins that can be a more expensive variety.
    one example of many: Someone may decide to make a 1972 Lincoln penny look "shiny and pretty" and ruin the value of a 300.00 variety of the otherwise common 1972 penny known as a doubled die.
    The Mercury dimes you cleaned here may be what are known as repunched mint marks PRMs, minor doubled dies, or even a very rare 1942/41 (300.00) coin.
    Be informed before deciding to make aa coin look pretty. Unless, of course, money is no object.
    dragon flyer
    dragon flyer
    1 year ago
    What, I'm the only one concerned about getting your toothbrush this grubby?
    drelectron
    drelectron
    1 year ago
    I agree that cleaning "valuable" coins reduces the value that's why I chose non-valuable coins, but probably a good idea to note something in the Instructable that cleaning older / more valuable coins should be done with discretion.
    WilliamB422
    WilliamB422
    1 year ago
    Cleaning old coins reduces the collector value, but this would be fun to do with coins that are really grubby. Even with a cleaned coin, if it's silver (1964 and older) you still have the silver value. Thanks for the tip.
    tomatoskins
    tomatoskins
    1 year ago
    This is a great way to clean up some old coins!
