Fast and Fun: How to Make a Stress Ball
  • Optional: you can wear gloves to prevent your hands from getting cornstarch on them.
  • Grab a friend to help you with this project!
Teacher Notes
Step 1: Gather Supplies
For this fun project, you'll need:
  • 1 Small Balloon
  • 1 Funnel (Make sure funnel is NOT rubber.)
  • 1 Cup of Cornstarch
  • 1 Pair of Scissors
  • 1 Permanent Marker
  • 1 Small Measuring Cup
  • 1 Pair of Gloves (optional)
Step 2: Blow Up Balloon
  • Blow up the balloon until it is 4-5 inches around. It should be a little bit bigger than your fist.
  • Do not tie it, but keep it inflated the best you can.
Step 3: Pinch the Balloon Closed
  • Pinch the balloon closed, leaving enough room for the funnel to be inserted.
Step 4: Insert the Funnel
  • Keeping the balloon pinched closed, insert the funnel inside of the balloon.
(DO NOT WORRY IF THE BALOON DEFLATES DURING THIS STEP!!)
Step 5: Fill With Cornstarch
  • Using the funnel and measuring cup, begin filling the balloon with cornstarch.
  • Only add SMALL amounts of cornstarch to avoid a clogged funnel.
  • Be sure to keep the neck of the balloon pinched around the funnel.
Step 6: Release Pinched Fingers
  • SLOWLY release your pinched fingers so the cornstarch can slide in the balloon.
  • Do NOT let go of the balloon and release your fingers completely.
Step 7: Finish Filling the Balloon
  • Continue adding cornstarch to the balloon until it is filled about 3 inches.
  • Adding small amounts of cornstarch, swirl the cornstarch around with your finger to work it into the base of the funnel and into the balloon.
  • (If you don't want to use your finger, a pen or other thin object will do just fine.)
Step 8: Squeeze Out Air
  • Pinch out any excess air inside the balloon by pulling tightly on the opening of the balloon.
  • It is important to eliminate any excess air that is inside the balloon in order to have an effective stress ball.
Step 9: Tie It Closed
  • Tie the balloon closed, as close to the cornstarch a possible.
Step 10: Cut Off Excess
  • Use your scissors to cut off the excess part of the balloon
  • Important: do not cut too close to the knot of the balloon
Step 11: Decorate
  • Using your permanent marker, decorate your stress ball any way you would like.
Be the First to Share
    • Art Skills Challenge
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    seamster
    6 months ago
    Great little project, thank you for sharing the details! : )
