Feed Cat Remotely Using Smartphone With Obniz
Introduction: Feed Cat Remotely Using Smartphone With Obniz
About: DIY electronics, javascript, IoT, obniz, programming, raspberrypi, arduino
Do you wanna feed your pets from outdoor? I have made a feeding machine which can be controlled on the browser using smartphone.
Step 1: What You Need to Prepare
  • Obniz
  • Battery or USB adaptor & cable
  • Screw and pipe
  • Servo motor ( unlimited rotation)
  • Pet food - as much as possible
Step 2:
Cut pipes and prepare the screw. I made a screw by using 3D printer. Then, connect screw to a motor. and put them into a box.
Step 3:
Connect servo motor to obniz.
io0: GND,
io1: VCC,
io2: signal
Then power up your obniz.
Step 4:
Write codes below and put food into the bottle. Food will come out from the pipe.
Step 5: Program
Please get the program from here
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Audio Challenge 2020
    • Maps Challenge
      Maps Challenge
