Felting a Mini Kitty From Your Cat's Fur
617
7
Introduction: Felting a Mini Kitty From Your Cat's Fur
My cat has a never ending amount of fur that comes out when I brush him. I always thought, "I could make a whole cat with all this fur!" Well, why don't I; it'd be hilarious, disturbingly adorable, and upcycling all at the same time. So, in this tutorial, I'll teach you how to make a mini pet with your pet's own fur.
For those who don't know, felt is a textile material that is produced by matting, condensing and pressing fibers together. It can really be made out of any material.
Step 1: Supplies
I didn't have to buy anything for this project. You just need some common household items.
-A handful of pet fur
-A sharp needle (they specifically make felting needles for this type of work, but it's not necessary to go out and buy one. Any needle will do)
-Thread to match color of fur
-2 small beads to match your pet's eye color (ok, I guess normal ppl don't have tiny beads laying around. You can use any small round object you find: buttons, squins, googly eyes, seeds, etc)
-Thimble (optional)
Step 2: Gather Fur
As I brushed my cat, I collected about 3 clumps of fur off his brush. It was more than enough to make a tiny kitty, but if you want to make a bigger version, then collect a lot more fur.
Step 3: The Body
Take a small bit of fur and roll it into a loose ball between your hands. This will mat it down a little bit and get the beginnings of your shape.
Take your needle and poke it into the ball repeatedly. This process will cause the fur to knot itself together making it compact and hold the shape you want. Make sure to poke all sides of the ball to shape it evenly. There will be A LOT of poking involved so be patient and be very careful not to poke your fingers. It might be best to wear a thimble on your thumb so you don't stab yourself. Even being slow and careful, I still managed to poke myself a lot lol.
After awhile the ball will feel firm and there will be less stray hairs sticking out. This is when you know you're done poking.
To turn the ball more into an oval shape for the body, take a small piece of lose fur and place it on one side of the ball. Poke the extra fur through the ball until they stick together and form one oval shape. You can repeat this process to make the body longer, if you'd like.
The more you poke, the denser your shape will be, but it will also get smaller with more poking.
Step 4: Head
Repeat steps from making the body to create a ball for the head. It's best to start off small and add to it.
To make the head bigger, take a small amount of fur and wrap it around the ball. Poke until they are knotted together.
Step 5: Attaching the Head to the Body
Place the head on the body where you want it to stay. While holding it in place, poke the base of the head where it rests on the body to knot them together. Be sure not to poke to far up the head because then you'll lose the round shape. You can also poke from underneath the body a few times into the base of the head for extra security.
Continue to poke along the base of the head until it is secure to the body.
If you lose the roundness of the head in the process, just poke into neck (where the head joins the body). This will compact that area creating more shape.
If the body wont stand by itself once the head is attached, then poke the bottom of the body to flatten it out a little.
Step 6: Ears
Make 2 tiny balls to sit on top of the head. This is where it gets a little tricky because the ears are so small; so be careful!
Rub one end of the ball between your fingers to create a pointy end.
Step 7: Attaching Ears
Start by holding one ear in place. Poke all around the ear, but pinch the end occasionally to keep the shape.
After that one is firmly attached, attach the other one.
Step 8: Tail
Take another small clump of hair and roll it between your fingers to create a cylinder shape. Poke and condense the fur. Hold the tail in place on the body and poke at the base of the tail where it meets the body (as you did to attach the head and ears).
To give the tail more of an S shape, fold the tail over and just poke a few times through the part that overlaps. The more you poke, the more bent the tail will be. Repeat this again further up the tail.
Step 9: Eyes
The eyes are attached with thread. Stick your needle in through the back of the head to come out the front where you want the eye. Put the bead on the thread. Put the needle back through roughly where the thread came out. You'll have both ends of the thread sticking out of the back. Tie the ends into a knot. Cut the excess as short as you can so the knot can be a bit more hidden.
Repeat for the second eye.
Step 10: Bam! You're Done
Lastly, trim any hairs that are sticking out.
Enjoy your new mini kitty!
Pocket Sized Contest
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Super-Size Speed Challenge
    2 Discussions
    RCEM
    RCEM
    1 year ago
    Thats so cute! Love it!
    Penolopy Bulnick
    Penolopy Bulnick
    1 year ago
    That is certainly a one of a kind felted cat :)
