Introduction: Fidget Spinner
In this instructable I will teach you how to make a 3D printed fidget spinner!
Step 1:
Open up Autodesk Inventor Professional 2017
Step 2:
Click on NEW to create a project and select standard(mm) in the metric folder. After you do this press create.
Step 3:
Press on "Start 2D Sketch" and then select the XY plane to start making your fidget spinner.
Step 4:
Use the circle tool to create two circles that are 22.1mm in diameter. Make sure that the circles are directly on top of each other.
Step 5:
Press on the dimension tool and select both dots in the middle of each circle, then make the line 32-35mm.
Step 6:
Create two more circles 37mm in diameter that are in the same spot as your previous circles
Step 7:
Create two vertical lines on each side of the circles
Step 8:
Select the trim tool and trim the inside of each circle.
Step 9:
Select the circular pattern tool and highlight all your work. Select the clicking tool and press on a dot in the middle of one of the circles. A fidget spinner with 6 sides should appear, change it to 3 sides.
Step 10:
Select "finish sketch" on the top right corner
Step 11:
Select the "extrude" tool and extrude your fidget spinner by 7mm.
Step 12:
Select the "fillet" tool and click on all three corners of your fidget spinner. Hold and drag to round out the fidget spinner to your liking.
Step 13:
Select the "fillet" tool again and select the front and back edge, set it to 2mm to round them off
Step 14:
