Fifteen Minute, Self-propelled Hovercraft
182,156
149
145
Introduction: Fifteen Minute, Self-propelled Hovercraft
This instructable coves how to build a hovercraft out of a foam tray, cardboard, and some other household items.
Teacher Notes
Step 1: Materials
For this project you need:
A foam meat tray (smaller is better)
Some non-corrugated cardboard (I used the kind in Kudos bar boxes)
A small 1.5 volt DC motor
A propeller that can attatch to the motor (I used one from an old RadioShack kit)
A nine volt battery
A nine volt battery snap
Scissors
A glue gun
A craft knife
Tape
Step 2: Make the Intake
The intake should be as short as possible to allow very little air to escape. Measure the length from the bottom of the motor to the end of the propeller blade, then add a half a centimeter or so. The top should be just wide enough to fit the motor on it without too much overhang. The angle of the back isn't crucial, but I have found 45˚ works the best. Once you have figured out the measurements and cut it out of cardboard, glue it all together with liberal amounts of hot glue.
Step 3: Make the Base
The base is just a foam meat tray with a hole in it. Trace the outline of your intake in the center of the meat tray, then cut it out with the craft knife. Be careful not to dent the bottom edge of the tray, as it could cause it to go off balance and touch the ground.
Step 4: Attatch the Intake to the Base
Now hot glue the intake to the foam tray, directly over the hole, with the meat tray facing down.
Step 5: Attatch Motor and Battery
Use the tape to attatch the motor to the top of the intake, and more tape to attatch the battery to the back, just past the intake. Make sure to leave enough room for the fan blade to move. Then attatch the battery snap to the battery.
Step 6: Finished!
To start, place the hovercraft on a hard, smooth surface. Put one of the wires from the battery snap through one of the holes in one of the contacts on the back of the motor and bend it so it doesn't come loose. Then, put the other wire through the other hole, so that it just barely stays there. That way, it's easier to remove when you chase it down. If the propeller blows the air forwards, reverse the wires. Also, this is a 1.5 volt motor, so hooking it up to a nine-volt is not good for it. Don't let it run for long periods of time or it will burn out the motor. It works by creating a high pressure zone inside the meat tray. The escaping air travels under the rim of the meat tray, causing the tray to lift off the ground very slightly. The top part of the propeller provides lateral thrust, causing the whole thing to move forward.
Be the First to Share
    • Sculpting Challenge
      Sculpting Challenge
    • 3D Printed Contest
      3D Printed Contest
    • Motor Vehicle Contest
    145 Discussions
    sw5308546
    sw5308546
    Question 1 year ago
    how fast can you go
    DandyDIY
    DandyDIY
    2 years ago
    for the intake are we supposed to make the air escape?
    TheLuigiLord
    TheLuigiLord
    3 years ago
    I made this and it worked wonders. I even added a switch to it!
    dmckn
    dmckn
    Reply 3 years ago
    Where did you get the motor and propellers?
    TheLuigiLord
    TheLuigiLord
    Reply 3 years ago
    Amazon. I was doing this for "Science Olympiad". I'm guessing you know of it. Anyways, I also just took meat trays from meat dinners. Sorry for the late response.
    EthanR48
    EthanR48
    Reply 2 years ago
    How did this work im doing it for the same thing, what did you place?
    _hhhaleyy
    _hhhaleyy
    5 years ago on Introduction
    Where can you get the batteries, my friend and I are doing this for our Science Fair?
    nitrojon
    nitrojon
    Reply 3 years ago
    Hi
    Sorry it might me a bit late for the science fair, but 9 volt batteries are small rectangular batteries that you might use in a smoke alarm or some toys. They have two connections on their top, and they can be found at supermarkets and battery shops, as well as hobbiest electronics shops. (ie a Woolworths, Coles, BI-LO, BatteryWorld, Jaycar). Just ask for 9V battery.
    nitrojon
    nitrojon
    Reply 3 years ago
    They are also known as PP3 9V batteries. PP3 is the sice of the battery but everyone knows them as 9Vs. Here's a pic in case I haven't described it well enough!
    ShioriToshiko
    ShioriToshiko
    4 years ago
    Any sort of lightweight fan should work in place if the propeller/motor? Like a pc fan? If you don't get back to me on that, I will try it anyway! EXPERIMENTATION! :D
    Thanks anyway!
    ShioriToshiko
    ShioriToshiko
    4 years ago
    Thanks anyway!
    VentureScout
    VentureScout
    5 years ago
    Nice and simple, good job!
    gamelord72
    gamelord72
    6 years ago on Introduction
    how does an rc helicopter work?....doesn't seem to match the concept of this model....
    Castle Seige
    Castle Seige
    12 years ago on Step 6
    Does the motor voltage affect how good it hovers?
    Dr. No
    Dr. No
    Reply 12 years ago on Introduction
    I only tried it with one motor, but I'm guessing it would.
