Figure 8 Loom
Introduction: Figure 8 Loom
I buy my paracord as i need it from the local chain craft store using coupons. It comes in various sizes and lengths. The cord comes in hanks that become a mess if you try to remove cord as you need it. There are various ways to change that hank to something easier to use
Teacher Notes
Step 1: Figure 8 Loom
In my (very) humble opinion the "Figure-Eight" set-up is the best method. It is simple make and easy to deploy the cord as desired.
I used two pieces of an aluminum rod for pegs and made the loom by drilling peg size holes in a piece of scrap lumber and placing a tie off (eye screw) to secure the standing end of the paracord.
Step 2:
Place the first peg in the first hole. Place the second peg according to the size and length of the cord you are using. In this case I am using 95 paracord - 25' long
Tie the cord to the tie off point and bring the cord above the two pegs.
Step 3:
Bring the cord around the second peg and above the first
Step 4:
Bring the cord around the first peg and above the second
Step 5:
Bring the cord around the second peg and . . .
Step 6:
. . . continue in this manner until there is about 1' of cord remaining
Step 7:
Bring the cord around the figure 8 and underneath the bight
Step 8:
. Bring the cord in the opposite direction a couple of times and . . ..
Step 9:
. . . tuck it under itself and pull snug.
Step 10:
Remove the figure 8 from the loom. Pull the cord from the "tie off" end as you need it
Be the First to Share
    • Trash to Treasure Contest
    • Rope & String Speed Challenge
    • Fix It Contest
      Fix It Contest
