Fix a Loose Wheel Center Cap
Finally I was able to find the correct size (outer dia. 57mm) for my Toyota however it was pretty loose when I tried to install into the factory stock O.Z. made Toyota rim. The plastic may become rigid over time or just simply not a perfect fit to this exact rim as the rim has an etching right where the "claws" of this cap would hold on.
I'd like to share a cheep solution that may help you with similar issues.
Supplies:
  1. Scissors
  2. Lighter
  3. Heat shrinking tube (for mine a d=13mm / 6.5mm was a perfect fit) - roughly 100-150mm was enough for the 4 caps.
Teacher Notes
Step 1: Remove the Internal Spring (if Present)
Step 2: Install the Heat Shirnking Tube
Step 3: Cut to Size
Step 4: Repeat
Step 5: Fire Up! (Shrink the Tubes)
Step 6: Re-install the Spring
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    Penolopy Bulnick
    16 days ago
    That's a really good idea for getting a better fit :)
