Fix an Annoying Bra
About: I like fixing and making things. Trynna get in the habit of completing small projects and work up from there.
This is my first attempt at publishing an i'ble. Having massive issues with it not saving and not being able toadd photos. Might be a bit brief as it's been like groundhog Day typing the same stuff... Typed loads and lost it all. Probably will update and improve plus if I do any after this they should be better!!!
Step 1: Supplies:
Annoying bra, sewing needle, thread similar colour to the bra, scissors, measuring tape, t, seam ripper, water soluble pencil, silicon based thread conditioner/hair product/shaving product,.
Step 2: Measure and Cut.
Measure the length of the strap at its correct length. Make sure the tape measure is taut and the strap is straight but not stretched, Asif is probably a bit elastic. Add 1.5cm to this and then cut. Remove the slidey buckle type thing and put it with wall the other small random metal/plastic items that you are keeping for no discernible reason.
Step 3: Fold and Sew.
Fold the edge over the triangle bit, fold over 1.5cm. Make sure the strap is not twisted, and the cut end is on the inside. See together, making sure that you are not just sewing the outer fabric and missing the elastic inside. Sew across the whole width of the strap.
Step 4: Repeat on the Other Side ☺
It helps if you make them the same... But my stitches changed
as I got in the groove.
Step 5: Ta Daah!!
Feel smug that you have actually completed a little project, and squashed one of life's little nuisNses
    • Faux-Real Contest
      Faux-Real Contest
    • Cardboard Challenge
      Cardboard Challenge
    • Toys Contest
      Toys Contest
    2 Discussions
    DIY Hacks and How Tos
    3 months ago
    If you have problems with losing your work, I would recommend doing the initial write-up on a word processor. That way if the site eats it, you still have a copy on your computer and you would probably have a better editing tools. I for one need a spell check and my word processor works much better at it.
