Fixing Brocken Apeture Blades
About: im 17 and i have a vast passion for making and have to keep busy with loads projects and love the outdoors and want to be a prop maker/ set maker
hello today we are going to learn how to fix a broken/stuck aperture blade on a vintage lens which was a cannon fd mount aslo please check my 2 min video first for a better perspective of how it is fixed and a subscription is allways great too also Ill show you how to turn any lens into a cine lens
Teacher Notes
Step 1: Takeing Mount Apart
undo the screw in the back of the fd mont and pull the mount of carefully , remember to keep the screws safe i use a magnetic bowl
Step 2: Leavers
in the picture, you can see this pin in the leaver on the mount and the leaver with the hole on the lens, when taking apart the lens I found these were not connected properly the pin should be in the hole this controls the aperture, connect these then screw the mount together ensuring they are both connected
Step 3: It Works
yey it works , we have now saved this item from going to the waste thank you for looking at this post, please tell me if I help fix your lens and please check my video
Art Skills Challenge
This is an entry in the
Be the First to Share
    • Art Skills Challenge
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
