Flashlight Upgrade
In this instructable you will learn how to upgrade a standart Chinese flashlight to Li-ion 18650 and micro usb charger.
Li-ion battery: I took from old laptop battery
Li-ion charger: 5 pcs
Supplies:
  1. Glue gun
  2. Scalpel
  3. Cutters
  4. Soldering iron
Teacher Notes
Step 1: Dissasembly
Unscrew the ring then find 1 screw and remove them by the Screwdriver.
What we have inside:
  • Plug
  • Step-down scheme
  • Battery
  • Switch
  • LED
Remove by the cutters: battery, plug and step down scheme
Step 2: Сompletion of the Body
  1. Take plug, cut wires and glu it to basic place
  2. Make hole for micro usb port by scalpel
Step 3: Wiring
  • Solder battery to charger keeping polaryty (battery + to B+ on charging board, battery - to B-).
  • Solider Out + to switch, Out - to led wire
Step 4: Gluing
  • Glue charge bord, battery.
  • Assembly flashlight
  • Glue gap
Step 5: Test
Camera does not transmit the brightness of the flashlight, it is brighter than it looks.
Thank you for listening
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
