Flexible Extension Holder Lamp Bulb E27
I apologize for my bad English, but I would really like to share my home-made.
This time I decided to make a simple flexible lamp to work in poorly lit places.
In contrast to the bulb with a wire, this option is much more convenient because you do not need to look for where to place the lamp
Teacher Notes
Step 1:
For manufacturing, I needed a case from an old power supply, an E27 bulb connector, a wire and a flexible tube.
I took a flexible tube for the wire from an old table lamp
Step 2:
Pulling out all the elements from the power supply unit, I soldered the wires to the plug and insulated them and screwed the flexible tube to the case.
Step 3:
On the other hand, fasten and connect the connector for the light bulb.
Step 4:
After that, glued the power supply case
Step 5: Finish
Is done. It remains to screw the light bulb and you can use
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
