Introduction: Flying Skateboard
Just want to do some different skateboard, flying skateboard, hah.
It doesn't have to be on land, it can reach a wider dimension.
Jet engine
The iron man reactor
Step 1: Build the Base Board
Build two triangular boards
Length: 87 cm
Wide: 150 cm
High: 14 cm
Length: 132 cm
Wide: 216 cm
High: 14 cm
Step 2: Connect the Two Parts
To make the structure more stable,
shorten the connecting part in the middle.
Since the current energy equipment is not enough to power the system,
I used two stark reactors to power it,
And a jet engine at the back.
Step 3: Make the Steering Pedal and Steering Shaft
A lot of flying skateboard in science fiction movies don't think about aerodynamics.Here we use four engines and a middle drive shaft,which can easily steer the flying skateboard
Step 4: Install the Fan of the Skateboard by Using the Circumferential Arrangement.
And make the fan blade Angle to play the power of the engine.
Step 5: Do a Good Landing Gear and Landing Gear Storage Bin
This allows the flying skateboard to take off and land, and reduces air resistance.
Step 6: Make the Wheels and Install Them
Step 7: Deal With the Details, Set Up the Materials, Spray Paint, Done!
