Fold a Shirt in Seconds
Introduction: Fold a Shirt in Seconds
Do you dislike the timely and hard task of folding shirts? Is your dresser or closet unorganized because of this? Well, you’re in luck! If you didn’t know, it’s actually possible to fold your shirt in less than 10 seconds. Keep scrolling if you want to learn this neat hack.
Step 1: What You’ll Need
You Will Need:
~ Short Sleeve Shirt
~ Clear, flat surface (i.e. ground, table, bed)
Step 2: Place Shirt on Surface
Place your shirt flatly onto the cleared space.
Step 3: Pinch Two Areas of the Shirt
Take your shirt and pinch it in two different areas with both of your hands. Your left hand should pinch the top of the shirt between the collar and sleeve. The other hand should pinch an area horizontally across from that, about in the middle.
Step 4: Grab an Area at the Bottom
Still tightly holding both areas of your shirt, bring your left hand all the way to the bottom of the shirt and pinch.
Step 5: Step 5: Lift Both Hands
Lift your hands into the air, still pinching the shirt. It should unravel and look something like this. Your fold is almost done! One sleeve should be left hanging.
Step 6: Step 6: Finish
Finish off by folding the hanging sleeve under the shirt.
You’re done! After about one try, this quick life hack should be down in a few seconds. It is unbelievably easy and can be learned by almost anyone. To whoever folds the clothes and does the laundry: hope you liked! (:
Be the First to Share
    • Exercise Speed Challenge
    • Pocket-Sized Speed Challenge
    • Super-Size Speed Challenge
    randofo
    randofo
    1 year ago
    Cool trick
