Foldable Drone
dji f450mm is the best frame ,but the problem is ,it is not easily transportable.So i decided to make my own foldable frame
Teacher Notes
Step 1: Design
  • take the printout of the design
  • take two printout of body
  • one printout of arm
Step 2: Making Body
  • paste the body print on acrylic sheet
  • cut it out
  • you can also use wooden plates
Step 3: Making Arm
Step 4: Assembling
  • connect the arm and body using screw
  • use double side tape at the end to reduce vibration
  • drill the hole for mounting the flight controller
Step 5: Electronics
Step 6: Making Landing Gear
  • i am using 4inch pvc coupler for landing gear
  • refer this video for more information
Step 7: Ready to Fly
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
