Folding Biplane Skateboard in Imitation of Uav by Fusion 360
Inspired by the uav, the two wings of the uav are combined with the skateboard to enable the skateboard to rise into the air.Because the open biplane skateboard is not easy to turn on the ground, so the design of a folding biplane.When sliding on the ground, fold up the wings is the same as a conventional skateboard.When flying, the wings open, the engine turns and flies in the air.
Teacher Notes
Step 1: The First Step Is to Construct the Wooden Surface of the Skateboard
The wood board has the advantages of good elasticity, strong toughness and easy access to materials. After constructing the board with a curved surface with double heads, cut the two ends into a circle and reserve screw holes on the board.
Step 2: Build the Basic Bridge and Wheels of Skateboard.
1.Build the regular part of the skateboard bridge with basic commands such as stretch rotation.
2.Use curved surface modeling to stretch the irregular part of skateboard bridge.
3.Build the wheels of the skateboard by rotating and stretching the corners, etc.
4.Mirror and duplicate two Bridges and four wheels.
Step 3: Complete the Construction of Conventional Basic Skateboard and Carry Out Details Modification.
1.To conform to the law of fluid dynamics and change the airflow, install two air knives to the slide plate.
2.Use hollowed-out wheels for better shape and lighter weight.
3.Modifies the edges and corners of the skateboard so that it is not harmful.
Step 4: Install Two Folding Wings
Skateboard Contest
Skateboard Contest
Be the First to Share
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    • Furniture Contest
      Furniture Contest
    6 Discussions
    giaoge
    6 weeks ago
    impossible design
