Arduino Fourteen Segment Display - شاشه من رقمين باستخدام اردوينو
Introduction: Arduino Fourteen Segment Display - شاشه من رقمين باستخدام اردوينو
About: I am interested in the development of Monozukuri-Based Educational Robotics that encourage students to imagine, design and manufacture mechanisms and robots from scratch.
This instructables provides basic guidelines to make fourteen segment display, basically the goal is to:
▪ Learn how control many LEDs by using Arduino Nano.
▪ Understand how to program the fourteen segment to display numbers by using different code functions.
Supplies:
Basic components:
1- Breadboard small size (2 units).
2- Leds (For one array we need 4 leds, so total we need 14 arrays x 4
LEDs = 56 LEDs).
3- Arduino nano (1 unit).
4- Jumper wires (male-male, male-female).
Basic tools:
1- Mini USB cable for Arduino (1 unit).
2- Arduino IDE software on PC.
Teacher Notes
Step 1: Built the Circuit.
Construction of LEDs on breadboard:
♧ To build fourteen segment display you should fix the LEDs on the breadboard in the form of No. 88 as the diagram shows.
♧ fourteen arrayes = each array is containing 4 LEDs.
Step 2: Connection of the First Digit.
• Connect the common cathode for all LEDs together with GND in Arduino board.
• Connect positive cathode for each array with Arduino pin as show above.
Step 3: Connection of the Second Digit.
♤ Once the circuit is ready, you will start doing some interesting experiments that can enhance your skills in writing the codesfor displaying any numbers of LEDs.
Step 4: Exercise 1: Show a Number.
The goal is to show number 1 on the display of fourteen segment.
Arduino program code (Show number 1 on the display).
int ledA = 10;
int ledB = 9;
int ledC = 8;
int ledD = 7; // Seven segment connected with Arduino
int ledE = 6;
int ledF = 5;
int ledG = 4;
void setup() {
pinMode(ledA, OUTPUT);
pinMode(ledB, OUTPUT);
pinMode(ledC, OUTPUT);
pinMode(ledD, OUTPUT);
pinMode(ledE, OUTPUT);
pinMode(ledF, OUTPUT);
pinMode(ledG, OUTPUT);
void loop() {
digitalWrite(ledB, HIGH); // Number 1 is ON.
digitalWrite(ledE, HIGH);
Step 5: Exercise 2: Show Number With Different Delays.
◆ The goal is generate numbers on display from 1 to 3 with different
delays.
◆ Main concept: How to control the speed of lighting in fast and slow speed by increasing and decreasing the delay time
Arduino program code (From 1 to 3 fast and slow sequence).
int ledA = 10;
int ledB = 9;
int ledC = 8;
int ledD = 7;
int ledE = 6;
int ledF = 5;
int ledG = 4;
int ledAA = A1;
int ledBB = A2;
int ledCC = A3;
int ledDD = A4;
int ledEE = A5;
int ledFF = 3;
int ledGG = 2;
void setup() {
pinMode(ledAA, OUTPUT);
pinMode(ledBB, OUTPUT);
pinMode(ledCC, OUTPUT);
pinMode(ledDD, OUTPUT);
pinMode(ledEE, OUTPUT);
pinMode(ledFF, OUTPUT);
pinMode(ledGG, OUTPUT);
void loop() {
orderslow();
orderfast();
void number1() {
digitalWrite(ledA, HIGH);
digitalWrite(ledD, HIGH);
digitalWrite(ledF, HIGH);
digitalWrite(ledG, HIGH);
digitalWrite(ledBB, HIGH);
digitalWrite(ledEE, HIGH);
void number2() {
digitalWrite(ledAA, HIGH);
digitalWrite(ledCC, HIGH);
digitalWrite(ledFF, HIGH);
digitalWrite(ledGG, HIGH);
void number3() {
void orderslow() { //from 1 to 3 slow.
number1();
delay(500);
off();
number2();
delay(500);
off();
number3();
delay(500);
off();
void orderfast() { //from 1 to 3 FAST.
number1();
delay(100);
off();
number2();
delay(100);
off();
number3();
delay(100);
off();
Step 6: Exercise 3: Show Even Numbers.
◆ The goal is to show even numbers (2, 4, 6).
◆ The main concept: How to control the generation of lighting LEDs to show the even numbers (2, 4, 6).
♧Arduino program code: (Show even numbers - Simple form).
void loop() {
even(); // put even function in void loop.
void even() { //Add void even to generate even numbers.
number2();
delay(800); //count in even mode.
off();
number4();
delay(800);
off();
number6();
delay(800);
off();
♧Arduino program code: (Show even numbers using WHILE function).
void loop() {
int n=0;
while (n<=98) { //while function generates even
numbers.
n=n+2;
show(n);
void show(int n) {
switch (n) {
case 1:
number1();
delay(500);
off();
break;
case 2:
number2();
delay(500);
off();
break;
case 3:
number3();
delay(500);
off();
break;
case 4:
number4();
delay(500);
off();
break;
case 5:
number5();
delay(500);
off();
break;
case 6:
number6();
delay(500);
off();
break;
Step 7: Exercise 4: Show Odd Numbers
◆ The goal is generate odd numbers (1, 3, 5) on the display.
◆ The main concept: How to generate odd numbers (1, 3, 5) using the WHILE function.
♧ Arduino program code: Sequence of odd numbers.
void loop() {
int n=-1;
while (n<=5) { //change the function in void loop.
n=n+2;
show(n);
Step 8: Exercise 5: Show Multiples of Number 5.
◆ The goal: Generate number 5, 10, 15 on display.
◆ The main concept: How to generate numbers (5, 10, 15) using the FOR function.
♧ Arduino program code: Show sequence numbers using FOR function.
void loop() {
int n=0;
for (int n=0; n<=95; n=n+5){
show(n);
Step 9: Exercise 6: Show Fibonacci Numbers.
◆ The goal: Generate Fibonacci sequence numbers on display (1, 1, 2, 3, 5, 8, 13, 21, 34, 55, 89).
◆ The main concept: is knowing how to generate Fibonacci sequence numbers from 1 to 99 using FOR function. (See the above table)
Fn = Fn-1 + Fn-2, Where Fn = a,Fn-1 = b,Fn-2 = c
♧ Arduino program code: Fibonacci sequence using FOR function.
void loop() {
int b= 1;
int c= 0;
int a;
show(c);
show(b);
a= b+c;
for (int a=b+c; a<99; b=a) {
show(a);
c=b;
a=b+c;
Step 10: Exercise 7: Show 1x1, 2x2, 3x3,...........nxn
◆ The goal: Generate sequence numbers (1x1, 2x2, 3x3..............nxn) on display.
◆ Main concept: How to generate the results of this type of sequence numbers on display using the WHILE function.
void loop() {
int a;
a= 1;
while (a<99) {
show (a*a);
a=a+1;
Step 11: Exercise 8: Show 1(2), 2(3), 3(4),.........n(n+1).
◆ The goal: generate sequence numbers (1(2), 2(3), 3(4).............n(n+1)) on display
◆ Main concept: How to generate the above on display by using WHILE function.
♧ Arduino program code: show sequence numbers using WHILE function.
void loop() {
int b= 2;
int c= 1;
int a;
a= b*c;
while (a<99) {
show (a);
c = c+1;
b = b+1;
a=b*c;
Step 12: Exercise 9: Show 1(3), 4(6), 7(9) on Display.
◆ Goal: generate sequence numbers(1(3), 4(6), 7(9)) on display.
◆ Main concept: is knowing how to generate the above by using the WHILE function.
void loop() {
int b= 1;
int c= 3;
int a;
a= b*c;
while (a<99) {
show (a);
c = c+3;
b = b+3;
a=b*c;
Step 13: Exercise 10: Show (1)(2)(3), (2)(3)(4), (3)(4)(5),.........n(n+1)(n+2)
◆ Goal: generate sequence numbers((1)(2)(3), (2)(3)(4), (3)(4)(5),.........n(n+1)(n+2)) on display.
◆ Main concept: How to generate the above by using the WHILE function.
void loop() {
int d= 1;
int b= 2;
int c= 3;
int a;
a= d*b*c;
while (a<99) {
show (a);
c = c+1;
b = b+1;
d = d+1;
a=d*b*c;
Step 14: Exercise 11: Show (1)(2)(3)/(4)(5), (2)(3)(4)/(5)(6), (3)(4)(5)/(6)(7).......n(n+1)(n+2)/(n+3)(n+4)
◆ Goal: Generate sequence numbers (1)(2)(3)/(4)(5), (2)(3)(4)/(5)(6), (3)(4)(5)/(6)(7).......n(n+1)(n+2)/(n+3)(n+4) on display.
void loop() {
int f= 1;
int e= 2;
int d= 3;
int b= 4;
int c= 5;
int a;
a= d*f*e/b*c;
while (a<99) {
show (a);
e = e+1;
f = f+1;
c = c+1;
b = b+1;
d = d+1;
a = d*f*e/b*c;
Be the First to Share
    • Trash to Treasure Contest
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
