Frame Free Glue Mounted Watercolour Painting
4,935
45
10
Introduction: Frame Free Glue Mounted Watercolour Painting
About: I'm a Melbourne based designer creating art & accessories featuring my own original designs in the form of watercolour and acrylic paintings, wood block prints, lino prints and laser cut objects. Many of...
A fresh, modern way to mount and protect watercolour paintings
It's quite a simple process: glue a painting to a wooden board or panel and give it a protective coating.
I have used a cradled wooden panel as my mount and protected the painting at various stages of the process with varnish and wax, to create the look of a box frame picture.
Products available here in Australia often differ from the ones frequently used in the various YouTube videos I have drawn my inspiration from, so I have documented my process and the products that I used.
Teacher Notes
Step 1: This Is Not a Reversable Process!
A word of warning, once you stick your painting onto the wooden panel,
its virtually impossible to get off and there is a chance the adhesive may seep through and spoil your watercolour. I started by practising on a couple of paintings I liked but wouldn't have a major drama over if I lost them. I began by just pasting a watercolour sketch onto a piece of scrap plywood, moved onto a small square wooden box lid, and then finally onto a commercial wood panel from my local art store, (pink flower).
Step 2: Materials You Will Need
A deep edge wooden panel
Heavy gel medium (acts as a thick glue)
Your watercolour painting on heavy paper
Clear varnish spray (optional)
Wax
A wide flat paintbrush for applying gel medium
Some water
Sharp craft knife
Fine sand paper
Brayer
Rags for cleaning up and soft rags for use with wax
Pile of heavy books
I used a 12" x 12" a 1.5" deep edge wooden panel by Artitude, I bought a pack of 3 from a branch of Eckersleys, the Australian art supply store chain, I have also seen them online and in other independent art stores.
My watercolour paper is 300gsm (140lb) I recommend the heavier the paper the better, I suspect the gel may seep through thinner paper.
I used Liquitex Matte Heavy Gel Medium, widely available here in Australia, I applied the medium with a flat wide bristle brush - a Gesso Brush from Mont Marte, again widely available here in Australia.
The wax varnish I used is by Langridge, an Australian company, bought from a local art store.
When I use spray varnish it has been White Knight, Crystal Clear Acrylic (from Bunnings!), there are many online sites that recommend Krylon Clear, but I haven't used it yet.
Step 3: Prepare Your Artwork
Trim your artwork to a size slightly larger (approx 1cm on all sides)
than your wooden panel, my panel was 30cm (12"), so I cut my work to 32 x 32cm. This allows for easy placement on top of the panel and gives enough excess paper to trim off after the paper is glued to the panel. without things getting cumbersome. At this stage you can apply a thin coat of spray varnish, leave to dry 24hrs, this is not a process to be rushed, I think its best to give mediums used at every stage a good time to cure.
Step 4: Apply Gel Medium (glue) to Your Painting
Place your painting face down on some clean paper (not scrap - you
don't want to mark your painting). Apply a thick coat of the gel medium to the back of the painting with a flat stiff brush, go right up to the edges (this is really important).
Use a brayer to even out your gel layer, as the gel is so thick this process should create some thick ripples, this helps the adhesion process. (Rinse your brayer immediately - the gel is sticky stuff).
Step 5: Glue Your Painting to the Wooden Panel
On another clean sheet of paper place your wooden panel face up,
carefully place your painting on top and position so it overlaps on all sides. Smooth the paper down onto the panel, you can use a clean brayer at this point to help. Once you are happy with the position and adherence, fold the edges over slightly by running your finger along the edge. Wipe away any excess gel medium with a cloth. Make sure there is no glue on the surface of the painting as this will stick to your paper sheet.
Place the frame with your painting face down on a clean sheet of paper, and weigh down with heavy books or wooden boards, make sure the first book/ board covers the entire wood panel - this will make sure you get an even distribution of weight. Leave to dry for another 24 hours.
Step 6: Trim Your Artwork
Place wood panel painting side face down on a cutting mat, again
protect the surface of your painting with a sheet of clean paper. Using a sharp craft knife carefully trim the excess paper from the frame, using the edge of the frame as a guide.
The edge of your paper should be flush with the wooden panel edge. Smooth the paper edge with some very fine grit sandpaper, this creates a really professional looking smooth edge.
Step 7: Apply Wax Coating to Picture
Finally apply some wax as a final finishing layer. Using a soft
cotton cloth pick up some wax from the jar (about 1/4 teaspoon to begin with) rub wax gently across surface of painting, in a circular motion, Keep applying as much wax as needed, but in small quantities to create an even coating. Wax the edges of the paper and also the sides - it doesn't harm to wax the wooden sides of the panel as well if you want to.
Don't press too hard, and leave overnight to dry.
Using another clean soft cloth buff the surface, you will get a slight sheen. Repeat the waxing process and dry again overnight. Buff with a soft cloth one last time, the more you buff the higher the sheen, so best to stop and check your painting as you go by holding up to the light at an angle to make sure you get the level of shininess you want. Its never going to be a gloss varnish like finish - but I only like to achieve a slight sheen on my works, so I stop early.
Your watercolour mounted on a deep edged wooden panel with glue is now ready to
display. I normally just hang these panels off wall hooks using the depth of the wooden frame, but picture wire can also be fixed to the inside of the frame.
Stick It! Contest
Runner Up in the
Stick It! Contest
Be the First to Share
    • Heart Contest
      Heart Contest
    • Fiber Arts Contest
      Fiber Arts Contest
    • Paper Contest
      Paper Contest
    10 Discussions
    DrugaP
    DrugaP
    27 days ago
    Hello,
    I'm interested in doing the same but it's for a client and it's larger scale (150x100cm). Until now I didn't have any experience with gluing paper that big on wooden board. Paper would be thicker like 200/250g. Can you please tell me what knowledge you have about possible duration of the perfect state? I'm sorry, my english is not best. I hope you understand me. I'm worried that after few months or years the paper would start removing it's self little by little from the wood. :(
    Thank you!
    KarenSmithDesigns
    KarenSmithDesigns
    Reply 27 days ago
    Hi, thanks for your question. I have used this method on 2 larger paintings each measuring 52cm x 66cm - so that's all I can comment on...
    After 1 year they are still intact, and have been exposed to temperatures from approx 10C up to 30C, hung on a wall, out of direct sunlight, and in dry (not humid) conditions.
    I used 300gsm paper, with Liquitex heavy gel medium glue.
    I had stretched my watercolour paper before I began the painting - so I started with a very flat piece of paper - no wrinkles or bumps.
    I used a roller to apply the glue (wash this clean as soon as possible)
    Over a large area I found I had to work really quickly to make sure the glue didn't dry as I applied it.
    I then weighted it down with lots of heavy books, on a large picture I was able to place books right inside the frame next to the panel I had applied the glue to, and more over the entire frame to make sure there was pressure on the edges. (I've taken a mock up photo to help you see what I did).
    I tried to get an even pressure over surface area, i.e. a few heavy books rather than a single small heavy weight which could apply uneven pressure.
    I left it for a good 24 hours to dry, my conditions were dry and warm.
    I hope this helps, I would love to see a photo of your finished work !
    Regards, Karen
    wood_panel_frame.jpgKarenSmithSweetPea.jpgKarenSmithsweetpea_easel2.jpgKarenSmithSweetPeas_Edge.jpg
    MichiganDave
    MichiganDave
    1 year ago on Step 7
    Such an interesting concept. I am impressed, and thanks for sharing. One question: do you think that the glue seepage could be countered by glueing a piece of paper between the artwork and the wood? I am thinking a different glue could be better for the art. Maybe, I'm not understanding the problem as well as I should, but the whole concept of inspiring.
    KarenSmithDesigns
    KarenSmithDesigns
    Reply 1 year ago
    Hi thanks for your comment
    Yes that's an interesting point, I guess you are thinking a non water based glue from back of painting to middle paper and then gel medium from that to the wood panel board?
    To be honest I personally haven't had a problem with seepage in the few paintings I have mounted, and find the heavy gel medium is just that - really gloopy and not very watery like regular PVA, so it sits on the surface of my paper (reverse side of painitng) rather than being absorbed.
    Its all very dependent on weight of paper, how much sizing is in the paper, type of glue, so as I said in my posting - always best to create a test piece first!
    Many thanks, Karen
    ChandraD14
    ChandraD14
    Question 1 year ago
    Couldn't doing the painting on a canvas panel be better so you wouldn't have the fear of the glue ruiningyour actual painting?
    KarenSmithDesigns
    KarenSmithDesigns
    Answer 1 year ago
    Hi, thanks for the question.
    Yes,if you can find a canvas panel that is for watercolour, sounds good!
    I personally really enjoy the flexibility of working with paints on watercolour paper, so this method (with its risks!) is the one I prefer.
    Regards, Karen
    misterxp
    misterxp
    1 year ago
    Nice instructable and good, clear instructions. Thanks for sharing!
    Kink Jarfold
    Kink Jarfold
    Nice precise work with a super-duper result!
    KJ
