Frankenstein Doodle
14
34, college student using this platform for school work
Weeeellll Hellllooo There!
Today I am going to teach you, step-by-step, how to draw a Frankenstein doodle! He's a pretty cute little fellow and perfect for decorating any kind of paper craft for Halloween. I use a version of this Frankenstein doodle to decorate my student planner for Halloween. Keep reading to learn to draw your own Frankenstein!
Supplies:
paper
pen
Teacher Notes
Step 1: Step 1
Draw an "open" box shape. This will be the beginning of Frankenstein's head.
Step 2: Step 2
Draw a straight horizontal line that "hovers" above the open box you just made. This line will form part of Frankenstein's hairline.
Step 3: Step 3
At each end of your horizontal line, add smaller vertical lines, reaching just past the edge of Frankenstein's still open head.
Step 4: Step 4
Draw a zigzag line from one corner of your unconnected vertical lines to the other corner of the other unconnected vertical line to "close" the box and complete Frankenstein's hair.
Step 5: Step 5
Draw two vertical parallel lines from the bottom of Frankenstein's head, this will form his neck.
Step 6: Step 6
Now you will draw two sets of parallel lines coming out of Frankenstein's neck to start his bolts.
Step 7: Step 7
Next, you will "close" the openings of your parallel lines forming your bolts with a "C" shape on the left side, and a backwards "C" shape on the right side. You have now completed Frankenstein's bolts!
Step 8: Step 8
Draw two circles as evenly as possible for Frankenstein's eyes, inside the box that makes up his head.
Step 9: Step 9
Add two colored-in circles inside Frankenstein's eyes you just formed. These two colored in circles will serve as Frankenstein's pupils.
Step 10: Step 10
Add a small "U" shape for Frankenstein's nose.
Step 11: Step 11
Add a more relaxed "U" shape for Frankenstein's mouth. You could also use a zigzag line if you prefer a more menacing Frankenstein.
Step 12: Step 12
Draw two horizontal lines outward from each side of Frankenstein's neck.
Step 13: Step 13
Draw two vertical lines downward to form the outside of Frankenstein's arms.
Step 14: Step 14
Draw two horizontal lines inward to form the hand openings of what will be Frankenstein's jacket.
Step 15: Step 15
Draw two horizontal lines to form the inside of Frankenstein's arms. They will also serve as the sleeves to Frankenstein's jacket.
Step 16: Step 16
Draw a "Y" shape to build the inside of Frankenstein's jacket. The top of the "Y" will serve as the neckline, the bottom as the seam of his shirt.
Step 17: Step 17
Add two lines to each short side of the "Y" to form triangles, this will will form Frankenstein's jacket lapels.
Step 18: Step 18
Add a "U" shape to the bottom of Frankenstein's left jacket arm to form his hand.
Step 19: Step 19
Repeat on the right side; add a "U" shape to the bottom of Frankenstein's right jacket arm to form his right hand.
Step 20: Step 20
Draw a straight horizontal line from one jacket arm to the other to form Frankenstein's waist.
Step 21: Step 21
Draw two vertical rectangles, side by side under Frankenstein's waist line to form his legs.
Step 22: Step 22
Draw two horizontal rectangles to form his shoes. Color them in. :)
Step 23: Step 23
Give Frankenstein some stitches! Add a horizontal line with smaller vertical lines drawn through it. Repeat anywhere you want Frankenstein to have stitches!
Step 24: Congratulations!!!
You have now learned to draw your very own Frankenstein doodle! Please feel free to edit and change him as you see fit to make him your own!
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
