Friendship Bracelet
Introduction: Friendship Bracelet
This super easy friendship bracelet is fun to make and share with your friends.
Supplies:
embroidery thread of your choice
Scissors
ruler
tape (optional)
Step 1: Choose Your Colors
You can use 1-6 colors on this bracelet. I chose these two colors because they reminded me of a campfire.
Step 2: Cut Your Embroidery Thread
Depending on how many colors you use will determine how many strands you will need.
1 color = 6, 24 in. strands of that color
2 colors = 3, 24 in. strands of each color
3 colors = 2, 24 in. strands of each color
6 colors = 1, 24 in. strand of each color
Step 3: Tie
Tie all the strands together
at this point you can tape down the knot (optional)
Step 4: Split Into 3's
By now you should have 6 strands
Split the 6 strands in to 2 groupings of 3
Step 5: Make a Four
Cross the right side over the left and make a four shape.
Step 6: Under and Over
Take the top strand and weave it under the first strand and over the top of the second one.
Step 7: Pull Tight
Pull both strands tight. Make sure the loop doesn't go over the first knot.
Step 8: Repeat
Repeat the same steps but make sure to do it on the other side.
Step 9: Repeat
Repeat the steps.
(You are basically tie knot over and over again)
Step 10: Repeat
This the bracelet halfway through.
Step 11: Finish
Continue knotting until you reach your desired length. Tie it around your wrist and make another for your friend.
Be the First to Share
    • Pumpkin Challenge
      Pumpkin Challenge
    • Halloween Contest
      Halloween Contest
    • Bikes Challenge
      Bikes Challenge
