Functional Mad Eye Moody's Eye Using Nodemcu
All Harry Potter fans might remember the Mad Eye Moody's Eye like the one above
Today we are going to build one like this using the nodemcu.
Supplies:
  • nodemcu 1.0 esp 12e module x1
  • servo motor x1
  • ir sensor x1
  • buzzer module (preferably low trigger activated,but not to worry if high trigger activated)
Teacher Notes
Step 1: Get an Info
All knowledgeable potterheads like me can simply ignore this step. I recommend watching this video for a quick overview.
I give the youtuber Harry Potter credits for the video.
Harry Potter is the property of J.K. Rowling and Warner Bros. No copyright infringement is intended.
Step 2: Connections
well make the connections as below and this step is over.
all vcc to nodemcu 3v through a breadoard.
all gnd to nodemcu gnd through a breadoard.
buzzer i/o to d6
ir sensor output to d7
servo sig to d4
Step 3: Coding
well upload the code using arduino ide below. if you don't know how to check out this awesome instructable by
osoyooproduct
https://www.instructables.com/id/How-to-Program-NodeMCU-on-Arduino-IDE/
the code is given below. if you are using a high trigger buzzer then the code is in the next step.
int ledPin = 12; // choose pin for the LED
#include #include "ESP8266WiFi.h" int ypos; int inputPin = 13; // choose input pin (for Infrared sensor) int val = 0; // variable for reading the pin status Servo servo; void setup() { // put your setup code here, to run once: Serial.begin(115200); WiFi.mode(WIFI_STA); WiFi.disconnect(); delay(100); pinMode(inputPin, INPUT); // declare Infrared sensor as input pinMode(ledPin, OUTPUT); // declare LED as output
servo.attach(2); //D4
servo.write(0); Serial.println("Setup done");
delay(2000);
void loop() { // put your main code here, to run repeatedly: Serial.println("scan start");
// WiFi.scanNetworks will return the number of networks found int n = WiFi.scanNetworks(); Serial.println("scan done"); if (n == 0) { Serial.println("no networks found"); } else { Serial.print(n); Serial.println(" networks found"); servo.write(ypos); //y-servo moves to new position
int delayAmount = random(800, 2800); //generate number between 500 and 2000 delay(delayAmount); // delay by the random amount for (int i = 0; i < n; ++i) { // Print SSID and RSSI for each network found Serial.print(i + 1); Serial.print(": "); Serial.print(WiFi.SSID(i));
Serial.print(" ("); Serial.print(WiFi.RSSI(i)); Serial.print(")"); Serial.println((WiFi.encryptionType(i) == ENC_TYPE_NONE) ? " " : "*"); delay(10); val = digitalRead(inputPin); // read input value if (val == HIGH) { // check if the input is HIGH digitalWrite(ledPin, HIGH); // turn LED OFF } else { digitalWrite(ledPin, LOW); // turn LED ON } } } Serial.println("");
// Wait a bit before scanning again delay(5000); }
Step 4: High Trigger Buzzer Module
well this the code for high trigger buzzer module . if you are not using it simply ignore this step.
delay(2000);
Serial.print(" ("); Serial.print(WiFi.RSSI(i)); Serial.print(")"); Serial.println((WiFi.encryptionType(i) == ENC_TYPE_NONE) ? " " : "*"); delay(10); val = digitalRead(inputPin); // read input value if (val == HIGH) { // check if the input is HIGH digitalWrite(ledPin, LOW); // turn LED OFF } else { digitalWrite(ledPin, HIGH); // turn LED ON } } } Serial.println("");
Step 5: Your Crafts
well as I'm not too good in crafts i took help of the following instructable by daronjay.
https://www.instructables.com/id/Mad-Eye-Moody-Mov...
*just remember not code or wire; in fact you don't need an adafruit trinket! *
Step 6: And Done...
now be the perfect potterhead and walk like an ex-auror. !!!
First Time Author Contest
This is an entry in the
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
    Penolopy Bulnick
    10 days ago
    Nice job :) Do you have a picture of your finished Mad Eye Moody eye?
