Funpocalypse: a Board Game
Creating Your Own Role Cards:
This is optional as we have uploaded pre-made character cards onto the website for you to download and print
1. Open your laptop or computer and start the Microsoft Word program
2. Start off with a blank document
a. If the program asks you what you would like to start with, click “Blank Document”
3. On the top of the page there is a list of tabs. Click the Insert tab
a. Typically the third tab from the left
4. Right under the word “Insert” on the list of tabs is a picture of a table along with the word “Table”
5. Click on the word “Table”
a. Make sure a menu drops down below the “Table” option, if no menu drops down try again.
6. Once the drop down menu appears, drag your mouse over the squares to make a custom sized table.
7. Drag the mouse over 2 horizontal squares and 18 vertical squares and double click the mouse.
8. Once the table has been created, insert your desired picture into the box.
a. You can upload a picture by using the copy and paste function or the insert picture function.
9. Insert your desired text below the card:
a. Center the text, type the role name and put “(C)” after the name
b. Click enter and start the text on the left side of the box Type “Attack: (insert desired attack points here)” and click enter
i. Normal base attack is 30
c. On the next line type “Health: (insert desired health points here)” and click enter
i. Normal base health is 100
d. On the next line type “Carrying Capacity: (insert desired carrying capacity here)”
i. Normal base carrying capacity is 5
e. On the next line type “Special Ability: (insert desired special ability here)”
Make sure you save your hard work!
Creating Your Own Event Cards:
This is optional as we have uploaded pre-made event cards onto the website for you to download and print.
1. Follow steps 1-7 from Creating Your Own Character Cards.
2. Insert your desired text below the picture
a. The text should start on the left side of the page.
b. Type the name of your created event followed by (E).
i. It should look like “Brain Freeze(E):”
c. Explain the card in detail so other players can understand what event is taking place.
Creating Your Own Game Cards:
This is optional as we have uploaded pre-made game cards onto the website for you to download and print.
b. Type the name of your created item followed by (G).
i. It should look like “Camel(G):”
c. Explain the card in detail so other players can understand what item they received.
Creating Game Pieces:
1. Put on your safety glasses and dust mask/respirator
a. The glasses are needed to shield your eyes from over-spray and paint that may linger in the air around the area.
b. The dust mask/respirator is needed to filter the air. The paint and fumes can linger in the air and are hazardous to breathe in.
c. It is also good to have the work space be in a well ventilated area with a lot of air flow. A garage(with the door open) is a good example.
2. Place the piece of cardboard down on the floor or a workbench.
a. Make sure that there is nothing close to the cardboard. There is a chance that over-spray from the paint will get on other objects.
3. Place the first dime down on the cardboard surface.
a. Make sure the surface is clear of dust and debris. The layer of paint will trap any particles on the surface once it is applied.
4. Grab the first paint can and shake it vigorously for 5 seconds
a. Keep the cap on the spray paint can when you shake it. Your finger could slip and accidentally spray paint.
5. Remove the lid from the spray paint can and try to keep the bottle as vertical as possible.
6. Press down the trigger on the spray paint can and paint the dimes
a. For best results start the paint stream next to the dime and move the paint stream side to side over the dime.
b. Go back and forth over the dime 3 times for a single coat.
7. Place the cap back on the spray paint can.
a. It should take approximately 30 minutes for the dime to dry
8. You may remove the safety glasses and dust mask/respirator when you are in another room or when you can't see the work space anymore.
a. Do not remove if you are still in the work space! There could still be paint and fumes lingering in the air!
9. To apply a second of paint redo steps 1 and 4-9.
10. Repeat these steps 4 times to create all 4 game pieces.
a. Remember to use a different color paint every time.
Supplies:
Supplies needed:
1. A computer or laptop
2. The computer program Microsoft Word
3. A printer Printer paper (at least 15 pages)
4. Extra ink cartridges for the printer
5. 4 cans of spray paint(4 different colors)
a. Preferably a can with the label “Paint and Primer in one”
b. The Primer will help the paint stick better and last longer
6. 4 dimes
7. A pair of scissors
8. A piece of cardboard(at least 1 ft x 1 ft)
9. A work-space
10. Safety glasses
11. Dust mask or respirator
Teacher Notes
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
