GEO ONE - CONCRETE PLANTER !
About: Almost Architect (student yet). I am a Digital Fabrication Designer with a twist of traditional methods. I have a design studio in Argentina that develops prototypes with 3d programs and cnc machines (laserc...
This is the Ultimate guide to do the GEO ONE Concrete Planter !
DON'T YOU WANT ONE OF THEM ????
I have designed this pot and shared the mold so that everyone can download it for free and do it anywhere in the world !! If you have a 3d printer, i challenge you to step up your 3d Printed projects to a new level !! If you dont have a 3d printer, dont worry ! You can download the files and print the parts on a local fab lab or 3d printer in your city. And then bring them to your house and have fun with this project learning the basics of concrete casting.
Supplies:
-3d printer working fine and supplies (PLA and Flexible filament)
*Or a 3d printer service near you !
-Concrete (water based only)
-Water
-Sealer (it can be brick or concrete sealer)
-Whatever you want to put into the GEO-ONE !!
Teacher Notes
Step 1: MY DESIGN PROCESS
This was how i designed it !!
I used a free software called BLENDER 3d.
Is very easy and intuitive to use ! I only watched some youtube tutorials and this was my first project with it.
If you have a 3d printer, i recomend you to lear this 3d modeling software.
Step 2: PRINT THE MOLD PARTS
Once i had the design finished, i modeled the mold.
You can donwload all the files -for free- on
https://www.thingiverse.com/thing:2918926
Is a 3 part mold + tiny locks to attach the sides.
If you have a 3d printer, here are some advices:
The sides have to be MIRRORED - not equals- and printed on PLA (solid filament)
The inside part can be printed on PLA too, but you will have to break it to demold the concrete.
So i recomend to print the inside part on FLEXIBLE Filament. It can be removed easily.
If you dont have a 3d printer, dont worry! Send the files to a 3d printer near you. The prints will cost some money but it worth the shot so finally you have some planters!
You can print it in the size you want !! Combine scales: 100% + 80% + 60% and you will have the 3 beautiful combo of the first picture.
Step 3: CONCRETE CASTING
As you can see on the video, the "model" goes upside down.
You will cast the concrete from the bottom of the Planter.
If you want to do a hole in the bottom for the water of the Plant, just attach a vertical silicone stick to the top/center of the inner part. The silicone is a -very easy to demold- material.
Info about the concrete mix. I use a -only water required- concrete. (without sand) Here in my country is called "Grouter" but in USA or UK it might be similar to the "quickcrete".
Experiment with concrete ! Add some color to the mix ! Marble them ! Cast with other materials like resin ! Or just paint it !
Step 4: DEMOLD AND FINISH
Once the concrete is dry, demold it and wash well the mold for another casts !
The molds lasts at least 5 times - With a slow print quality and a good wash of the mold it can last up to 20 casts.
To achieve a perfect finish use a Concrete Sealer of your choice.(Acrylic or solvent based). Just wipe the concrete surface and let it dry. With each layer of sealer, the concrete becomes less penetrable for liquids and creates a smoother finish. Apply it on the inside part too.
If you end up crazy like me you will be doing thousands after the first one !
Step 5: PLANT IT OR CANDLE IT !
Last you need is to Plant your beautiful plant into the GEO-ONE !
Or do the amazing thing to Cast some resin Candle into it !!
Now the only thing you have to do is give it some love and take a photo of your make !!
Experiment with scales - colors - plants - candles - paint !
Join the Geo-One Community !! Don't make just one !
Today the thingiverse publication has 25,000 downloads ! I really love to see the makes on the web !
Post it on instagram with my tag @esparapse and dont forget @instructables too !!
U can also hashtag #3dprintedmold and #geonepot !!
Stone Concrete and Cement Contest
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    3 Discussions
    seamster
    17 days ago
    I really like the results! Great looking little planter! : )
    Penolopy Bulnick
    5 weeks ago
    I love the design :) Was it difficult to model the mold once you had the planter design?
    esparapsePenolopy Bulnick
    Reply 5 weeks ago
    Just a couple more steps on blender. There you have to know how the mold will be assembled and then test it how responds to the concrete cast. It wasn't so easy because i've tried different thicknesses and sizes. At the end i came out learning new 3d modeling, 3d printing and concrete casting skills !
