GROUND SCREW INSTALLATION TOOL FOR FENCE
Introduction: GROUND SCREW INSTALLATION TOOL FOR FENCE
Teacher Notes
Step 1: Built the Tool to Install Ground Screws
You need the following parts to build the tool:
4 peaces of metal profiles
2 screws
1 Drill 34mm
welding machine
1 peace of wood
a round tube with 33,7mm diameter
Drill and weld the tool according to the photos . The ground screw installation tool is divided in two parts. So it is possible to drill the ground screw extremely deep into the ground. I needed to do this because I had bought an filed fence (Wildzaun) and wanted to install the Fence with ground screws. The offered installation tool could not drill the ground screw 15cm deep into the ground, so I decided do design my own one.
It worked well and I was able to install my fence post with the ground screws.
Costs :
10-14 euros for the metal profiles
Step 2:
Be the First to Share
    • Trash to Treasure Contest
    • Rope & String Speed Challenge
    • Wearables Contest
      Wearables Contest
