Introduction: Gears of War Cog Tags
This is my first instructable and these are my cog tags from the video game Gears of War.
My cog tags are made out of 3mm aluminum and were both engraved and cut out using a CNC Mill
Materials
-3mm Aluminum
-chain, string
Machines Used
-CNC Mill
-Buffing Machine
Step 1: Engraving and Cutting Out
First i engraved the aluminum and then cut it out on the CNC mill.
I used a 60 degrees vbit for the engraving and a 3mm ball nose bit for the cut.
Found that cutting it out at a slower speed gave the best results.
Step 2: Sanding and Polishing
I then filed Down any sharp and uneven edges and sanded it with wet n dry sandpaper starting with 240 then on to 360, 600 and finally 1200
I then went and polished it on a buffering wheel
Step 3: Finished
Now just attach the string or chain and wear
Jewelry Contest
Halloween Props Contest
