Generating Tones of Different Kinds Using Mathematical Equations (MathsMusic) Arduino
About: Learn, Share , think, try Make it Simple :)
Project Description:
New journey has begun where ideas can be easily implemented using open source community (Thanks to Arduino). So here is a way
· Look around yourself and observe your surrounding
· Discover Problems which needs to be solved
· Think , Try and keep learning and share
· Most important what I call is KEEP IT SIMPLE :)
· Repeat
My intention was to make a musical based project using arduino platform
So I searched over internet and found amazing creative projects but I wanted to make my own stuff!
So I came across this tone() function from arduino library. Below is a link you can find descriptive information about it
https://www.arduino.cc/reference/en/language/funct...
Now after reading about tone() function ideas started its journey.
Basically tone() function as you would have read generates Sound of Some frequency you pass it in a parameter. So I thought how can I use this single function to generate different kinds of sound ?
Answer was in mathematics we all use maths everyday its logic its about solving mysteries
Of this universe (Sentence from famous Numb3rs tv series)…
Idea is to make sound which can be generated using mathematical equations let’s call it MathMusic
In this Project I used :
· Area’s equation of Simple Geometrical Shapes (Square, Rectangle, Parallelogram, Triangle and circle)
· Quadratic Equation and Fibonacci Series.
to generate sound. Now you can expand this project and discover some new music using different equations or formula …
Step 1: Stuffs You Need to Make This Project
Tools Required to Make this project:
  • Arduino UNO board
  • Speaker or buzzer i would recommend speaker for good quality of sound
  • one 220 ohm resistor to secure circuit from damage
  • Jumper wires to connect arduino and speaker
Software
You must install Arduino IDE to upload your programs from computer to board.
if you don't have no worry Below is a link to install Arduino IDE
https://www.arduino.cc/en/Main/Software
Step 2: Schematic
You can also make your circuit using below link
http://fritzing.org/home/
Step 3: How to Run the Program Using Arduino
First of All You need to connect the Arduino Board to your pc or computer through usb cable
Then Download and install Arduino IDE Software link has been given.
At Last Download the zip file which contains source code of this project
So Start and make something new out of it !
Step 4: Demo Video
Step 5:
    • Paper Contest
      Paper Contest
    • Warm and Fuzzy Contest
    • Sweet Treats Challenge
    2 Discussions
