Genesis (BATCH AI)
Introduction: Genesis (BATCH AI)
About: I like to code in batch and share it to the world!
This program, (Genesis), is a program I've been working off and on to produce over the past year. (Since June 29th, 2017 to be exact.)
Anyway, I decided that it was in a really good state to be able to release to the world here on instructables!
Genesis can do many things, such as calculating, opening apps, and even talking! (vbs)
The current version for Genesis is: 4.7
(I forgot to save the patch notes before 4.0)
4.0 Update notes:
Huge overhaul on the 'Chat' function to make it actually function well as a 'chat room'
Small changes to the 'learn' function to make it more efficient.
4.3 Update notes:
Tweaks to the calculator function so you can clear it to restart an equation
Removed the 'press any key to continue' warning when you first login
4.7 Update notes:
Fixed a major bug where custom responses would not work
Changing the color of the screen now tells you what you changed it to
Made it more efficient to type out sentences with punctuation
Teacher Notes
Step 1: Downloading the Necessary Files
To download Genesis, download the 'Genesis.bat' that's on this page. (Place it in its own file if you want to.)
What is the 'ChatAddon.bat' for? Well, in the Genesis program, you have the ability to start up your own little chat room and are able to talk into it. Well this feature requires a second app, and since the chat room isn't vital for the other uses, I went ahead and made it separate. If you want to be able to use the chat room, you can go ahead and download the ChatAddon. To implement the addon though, run Genesis once so it makes the necessary files, and then open the file, 'GenesisFiles' , that Genesis made, and then click on the file 'Addons'. Here, you can drop the 'ChatAddon.bat' and should be able to use the chat function!
Step 2: Recognizing My Inspiration!
Part of my inspiration and help came from a batch AI called Alice. The link for Alice is right here: https://www.instructables.com/id/AI-ChatBot-in-Batch-File/
1 Person Made This Project!
  • Trash to Treasure Contest
  • Raspberry Pi Contest 2020
  • Wearables Contest
    Wearables Contest
Hello there!
We're glad you want to share something with the Instructables community!
And we’re here to help you out.
In order to be published live on the site, Instructables must consist of the following things:
- Multiple steps showing how you made your project
- Written instructions in each step
- Your own original images
Beyond making your Instructable simply publishable, this guide (https://www.instructables.com/id/How-to-Create-a-Feature-Worthy-Instructable/) explains what is required to have your Instructables featured by our site editors. It’s very helpful, and definitely worth checking out.
We would love to review your project again after you have made the necessary edits, and we will publish your project if it is eligible.
If you have any questions, please feel free to ask right here or send us an email at service@instructables.com.
Best,
Instructables Community Manager
