Germinate Your Own Seeds in These 10 Simple Steps
32
Introduction: Germinate Your Own Seeds in These 10 Simple Steps
You can buy "ready made" plants in a gardening store, but it can be much more fun as well as being cheaper to grow them yourself from seed.
Supplies:
Seeds you are wanting to grow.
Hydrogen peroxide.
Soil or paper towel or rooter plugs.
Spray bottle.
Heat mat.
Light source.
Teacher Notes
Step 1: Timing When to Start.
Look up the hardiness zone of the area you live in to help plan when you should start your seeds.
Step 2: Read Instructions
If you already have your seeds in hand, check your seed packet for germination times and read the instructions on when the plant should be transplanted.
Step 3: Select Seeds
Select the seeds that look most viable. You want to pick seeds that aren't cracked or look like any mold has grown on them.
Step 4: Sterilize Seeds
Sterilize the seeds by making a diluted hydrogen peroxide and water solution. Add add 1 ounce of 3-percent hydrogen peroxide to 1 pint of water.
Step 5: Choose Medium
Choose a medium of choice to germinate the seeds in. Common ones are soil, paper towel or a starter plug like Rapid Rooter (I chose the latter).
Step 6: Hydrate the Medium
Spray the medium with a spray bottle with water. You want the medium to be moist. Too wet and you'll drown the seed, too dry and it will desiccate.
Step 7: Heating Mat
Put a towel on a heating mat. Then put the seeds on the mat. This will help them germinate by increasing the temperature. You want it between 70-80 degrees if possible.
Step 8: Keep Medium Hydrated
Throughout the germination process you'll need to make sure that the growing medium stays slightly moist. You'll probably have to spray it with water every few days.
Step 9: Light Source
After you see the seeds start to poke through the growing medium, you'll need to add a light source.
Step 10: Germination
Have patience. The germination process can take days or it can take multiple weeks. It depends on a number of factors.
Be the First to Share
    • Trash to Treasure Contest
    • Rope & String Speed Challenge
    • Wearables Contest
      Wearables Contest
