Getting Started With Attiny 85 - Smallest Micro Controller Chip
About: Share Knowledge about Arduino, ESP,GSM,Basic Electronics, DIY PROJECTS, Raspberry pi
In this blog we are going to learn about Attiny 85 - the smallest micro controller chip. Attiny 85 is a micro controller chip which can operate up to a frequency of 20 MHz. This is a high performance, low power chip, 8-bit EVR RISC based Architecture.
Attiny 85 Description -:
It has 8 kilobytes of in-system programmable flash memory, 512 bytes of RAM, 6 General Purpose Input Output Pins. It is programmable the Arduino IDE and hence makes things much more easier. It has 32 General Purpose Registers, One 8-bit high speed timer counter, Analog to digital converter, External and Internal interrupts, 4-channel 10-bit Analog to Digital converter. It also consists of a programmable watch dog timer with internal oscillator. Its operating voltage is between 1.8V to 5.5V.
Applications -:
There are various applications of Attiny 85
  • Used in development Boards
  • Industrial Control Systems
  • SMPS and Power Regulation systems
  • Embedded systems like Coffee Machine and Vending Machine.
  • Display boards
  • Peripheral Interface Systems
Teacher Notes
Step 1: Where to Buy?
Click here to buyAttiny 85
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
