Git Lit: the Prism Project
Introduction: Git Lit: the Prism Project
Create the prism, but with LED lights instead of something cooler like actual light.
Teacher Notes
Step 1: Obtain Materials
The following materials are used in this project:
One meter stick
One Protractor
One #2 or light pencil
One 0.7 m x 0.6 m sheet of white paper
One Eraser
Two 8B pencils
Two Alligator Clips
45 9-Volt Batteries
LED Lights of these colors:
10 White
5 Red
5 Orange
5 Yellow
5 Green
5 Blue
5 Purple
Scotch Tape
Step 2: Draw an Equilateral Triangle
Use the meter stick to draw a triangle with the 8B pencil. For perfect angles, use the protractor. The triangle shown here has 11 cm sides with 30 degrees at each angle. If needed, use the #2/Sketch pencil to create a height line or for making marks. Do NOT use the 8B pencil for markings.
Step 3: Draw the Lines for the Colors
Since this is supposed to represent the prism, use the 8B pencil and draw lines similar to the picture shown. There should be one line (for the white LED lights) on the left side of the triangle and the right side should have 6 lines (one for each color). For these lines, press the pencil harder. They should be darker than the rest of the triangle. The gaps should be every few centimeters (enough for five lights for each color) the lights will be placed there. Make sure to connect the ends of the multiple lines with one line connecting them all together. This where the alligator clip with the positive side of the battery will be.
Step 4: Place the White LED Lights on the Single Line.
After making the gaps (Should be 10), place a white LED on each gap. The prong ends of the LED lights should be in a straight line so both ends touch the graphite, as shown in picture. To keep it in place, take a small piece of tape and place it on each prong end.
Step 5: Place the Other LED Lights on the Multiple Line.
Repeat the previous step, but with the other lights on the right side of the prism.
Step 6: Attach the Batteries Together
If you didn't notice before, this is a High Voltage project.Take two of the 9V batteries and fit them together so positive end of a 9V battery is in a negative end of the battery (but not both) so it is offset. Add the other 43 batteries together, repeating the pattern so it is one large battery. Once again, this is a High Voltage project. After putting the batteries together, clip each of the alligator clips at each end, one on the positive and one on the negative.
Step 7: Clip Them to the Graphite.
Take the positive gator and clip it to the multi-line ended line on the graphite. Then take the negative gator and clip it to the end of the single line and the lights should turn on. Unfortunately, some tweaking will be needed as the lights are very dim and some don't show at all, but when that's figured out, the instructable will be updated!
Be the First to Share
    • Sculpting Challenge
      Sculpting Challenge
    • Tiny Speed Challenge
    • Clocks Contest
      Clocks Contest
