Glowing Jar Decoration
887
15
Introduction: Glowing Jar Decoration
This is a project I completed with my students intended to be a Christmas decoration. However the paper insert and color of lights could be changed to match any occasion or season. It is easy and cheap enough to provide all the materials for a whole class without breaking the bank. It's engaging enough that it keeps students interest, gets them doing design work with Google Drawing and provides them an opportunity to play with some LED tape which is just fun stuff.
Supplies:
-Pint Mason Jar
-LED tape with sticky backing and appropriate power source
-Tempera paint (I used white)
-Computer with printing capabilities to create 8.5" x 2.75" paper insert
-Scotch Tape
Teacher Notes
Step 1: Step 1: Prep the Jar
I choose white paint to use in the bottom of the jar, however depending on the theme your going for I'm sure any color would work. Perhaps if you were going for a Halloween theme you might use orange lights and perhaps black paint.
The paint helps send more light through the paper and makes for a nice glow.
Step 2: Step 2: Design the Insert
I used Google Drawing to design the paper insert to go inside the jar. I set the dimensions to 8" x 2.75" and then shared the document with my students via Google Classroom. This way they could design to their hearts content and not worry about going outside the boundaries. Simple designs taking advantage of clip art or simple shapes are the best. The key to a good insert are bold dark shapes. Fine details will not show up when lit up in a dark room. When cutting out the final insert you will want to cut it out as 8.5" x 2.75".
Step 3: Step 3: Set Up the LED Tape
For my project I provided students with a small segment of blue LED tape with sticky backing. Not a lot is needed for this project. I used snap on battery connectors so I could power it with a 9v battery.
Step 4: Step 4: Put It All Together
I first inserted the printed scene upside down. A little Scotch tape helps to hold it in place. I then attach the LED tape to inside lip of the jar.
Step 5: Step 5: Light It Up!
When ready just plug in the battery, replace the jar cover and turn the jar upside down. In a dark room it makes a beautiful glow showing off the scenery pattern.
Make it Glow Contest
This is an entry in the
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Warm and Fuzzy Challenge
    • Wearables Contest
      Wearables Contest
    2 Discussions
    droberts_Frankfort-Schuyler
    Best Answer 6 weeks ago
    Amazon. I can't find the same LED I had bought before, but you can get a similar style 16.4ft roll for $9.
    https://www.amazon.com/Water-Resistance-Waterproof-Flexible-Cuttable-Lighting/dp/B01HRMPDC8/ref=sr_1_8?keywords=LE+16.4ft+300+Units+SMD+5050+LED+Flexible+Light+Strip%2C+Blue%2C+12V%2C+Non-Waterproof&qid=1575740621&sr=8-8
    Here are similar connectors 10 for $6.50
    https://www.amazon.com/ESUMIC-Quick-Connector-Female-Adapter/dp/B00XVU3CD8/ref=sr_1_1?keywords=2Pin+Quick+Connector+to+DC+Female+Adapter+Cable+for+3528+LED+Light+Strip&qid=1575740944&sr=8-1
    Here are some of the 9v battery attachments 12 for $6
    https://www.amazon.com/gp/product/B01BHPP1HI/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    Perhaps with some digging around there are better quality parts to be had, but I suspect these will do what you'll need. I let my students play around with LED tape for all sorts of things, so I buy cheaper stuff when I can find it as I'm not too worried about it holding up and lasting a long time (though I've never had any go bad, even the cheap stuff is fairly durable). We have lit up posters and displays for various projects, lit up lockers and picture frames, its fun stuff for creative minds. There are no special tools needed, just cut with scisors and snap it togeather. I hope that helps.
