Gold Cement Earring and Necklace
6,872
40
13
About: Hello, my name is Auroris. Every day we have the opportunity to learn new things, to rethink tired processes, and to improve the way we work.
Hi friends!
It turns out that cement can be used to create jewelry! A creative solution for those who prefer uncommon jewelry is Gold Cement Earrings and Necklace. It looks stylish and cool. You just have to make a pendant, purchase accessories for jewelry, and a spectacular DIY Set is ready!
Supplies:
    • White Cement - 2-3 tablespoons
    • 24k Gold Leafs
    • Plastic straw, medium diameter
    • Cardboard
    • Adhesive tape
    • Sandpaper
    • Super Glue
    • Needle nose pliers
    • Brush
    • Ruler
    • Pencil
    • Cutter
    Accessories:
    • 50 cm chain
    • 3 eye pins
    • 1 small jump ring, gold plated silver
    • 1 bigger jump ring, gold plated silver
    • 1 lobster clasp, gold plated silver
    • 2 earring findings, gold plated silver
    Teacher Notes
    Step 1: Pendant Mold
    We will use non-corrugated, heavy cardboard to make our mold. Cut out a triangle, to use as a base. Then cut a strip - 1 cm width. Mark the size that you need to make the borders, and trim. Coate the inner sides with tape. Try to avoid wrinkles on tape. Shape the mold with your hands.
    Join the sides and stick them together on the outside, with packaging tape. Add packaging tape on every folded edge of the mold. We need to keep the cement inside the mold) Insert an eye pin into the top of the mold that we made.
    Step 2: Earrings Mold
    Take a plastic straw and cut two small pieces. I use a little bigger in diameter straw than a classic one. Secure it vertically to the cardboard with tape. I forgot to cover cardboard with the tape (you can see in the picture that cardboard, used as a base layer, became wet), but it really doesn't much matter.
    Step 3: Prepare the Mixture and Fill the Molds
    The desired texture looks like thick yogurt. Stir the concrete thoroughly, be sure no lumps remain in the mixture. When your mixture is ready, pour a small amount in the mold. Shake it a little to make the layer even.
    Your necklace pendant already has a hook, now insert the eye pins into earrings pendants.
    TIP: It's more easy to fill the mold if you will use a syringe
    Step 4: Leave the Cement to Dry for About 24 Hours
    Use your cutter to make slits in the cardboard, then pull and remove your pendant from the mold. To take out the cylinder pendants, just carefully push from the bottom using pencil end.
    Air bubbles! Don't panic... them can vary from piece to piece - due to the handmade process, it's your sign :)
    Step 5: Smooth & Polish Edges
    Use sandpaper to make the edges and corners of the triangle pendant more smooth and polished. The cylinders actually need polish only on the top and bottom surface.
    I use very fine sandpaper - 240 grit
    Clean the shapes with a moist paper towel from dust.
    Step 6: Decorate the Necklace Pendant With 24k Gold Leaf
    I buy 24k gold leaves in the Cake Decorating Shop. It's edible, and you can use it for adding shimmer and sparkle to your cake decorating. But today, we will use it in a different way.
    Tape the borders and apply a thin layer of super glue. Take a brush and very carefully tear off a piece of leave. Be gentle here, you can easily tear your gold leaf if you press too hard.
    Once your gold leaf is in place, you’ll need to smooth it down to attach it to the pendant. With light pressure and soft strokes, brush your leaf onto it. Wait for complete drying, brush all unglued parts, and remove the tape.
    Step 7: Decorate the Earrings Pendants With 24k Gold Leaf
    For the earrings pendants, do the same as in the previous step. Glue with Super Glue, apply the gold leaf with a brush and let it dry.
    Step 8: Attach a Pendant to an Earring Hook
    Open the ring on the earring hook, attach it to the eye pin, and close it up.
    Step 9: Assembling the Necklace
    Open the ring on the lobster clasp and attach it to the one end of the chain, and close it up. Attach to another end of the chain one more jump ring.
    Our chain is ready, it remains to join the pendant, and voilà!
    Step 10: Final Pictures
    Hope you liked this instructable and if you did, please vote for me in the "Stone Concrete and Cement" contest.
    xo, Auroris ;)
    Stone Concrete and Cement Contest
    Be the First to Share
      • Art Skills Challenge
      • Make it Move
        Make it Move
      • Teacher Contest
        Teacher Contest
      13 Discussions
      faltuusehe
      20 days ago
      Amazing get a new DIY Idea.
      thepoisonivy
      25 days ago
      Lovely! And about the 'dad comments'...pfft. Classic.
      N6REJ
      27 days ago
      Just one correction. That is "white cement" NOT concrete. concrete is cement that has agrigate in it. you probably don't want any aggregate unless your trying to achieve that look. Naturally it weighs more too. Many people use those terms interchangeably, however, in this case, its important not to.
      Oh, one other thing, there are several kinds ( not just brands ) of "superglue". The best place to get high quality CA is at a hobby store which caters to remote control airplanes. "Zap" is one of the best brands. Mosts common variants are "thin", "thick", "slow" & normal. You'd probably have more satisfaction by using "slow" in this case as it allows longer working time. "normal" CA cures in literally in just a few seconds.
      Anyway, interesting article.
      AurorisN6REJ
      Reply 27 days ago
      Thank you for your detailed comment. You are absolutely right, I will edit the "white concrete" to "white cement". I use only cement and the final results are very light as you mentioned. And thanks for info about superglues ;)
      Krell Metal
      27 days ago
      I've been a jeweler in Philadelphia since 1977 (retired now) and I'm hard to impress because I've seen it all. I like these!
      AurorisKrell Metal
      Reply 27 days ago
      Thank you! It's nice to hear that from the specialist :)
      Helder Cabral
      4 weeks ago
      That concrete looks like corian. So clean and whitish. It contrasted nicely with the gold leaf. Congrats.
      AurorisHelder Cabral
      Reply 4 weeks ago
      Thank you. My dad asked if these earrings are cigarettes))) He just didn't understand my minimalistic vision... lol
      Penolopy Bulnick
      4 weeks ago
      These are so simple and beautiful! White concrete seems like a fun material to work with :)
