Good Luck Knot Lanyard
I lanyard uses the arms of the good luck knot to make the loops of the lanyard.
I used a 42" length of 1/4" cotton cord to make the large lanyard.
I used a shoelace of the same size in the tutorial
I used proportionally shorter cord to male smaller (can also be used as zipper pull)
Teacher Notes
Step 1:
Fold your cord so that one end is 12" longer than the other.
Step 2:
Bring the other end of this large loop to form 2 loops. These loops will be larger than the loops in the finished knot.
Step 3:
Put a dowel over the center of the loops.
Step 4:
Bring the two ends over the dowel.
Step 5:
Bring the top loop (call it A) over these two ends.
Step 6:
Bring the remaining loop over A and under the bights formed in step 4.
Step 7:
Tighten the knot
Step 8:
Turn the knot over and bring the right hand loop to the left as shown.
Step 9:
Bring the legs down across this loop.
Step 10:
Bring the last loop over the legs and under the bights as shown. Tighten the knot.
Step 11:
Take the longer leg and form the top loop of the lanyard.
Step 12:
Wrap this end around the loop and the shorter leg two or more times
Step 13:
Bring the end through the middle of these turns and tighten. The knot is complete. Trim them ends
Be the First to Share
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    • Furniture Contest
      Furniture Contest
