Grilled Butter Onions
About: Michael's Test Kitchen - FOOD - SUGAR - RECIPES
There are so many different types of things you can grill, but why not stick to the classic - onions? Just because onions may seem boring doesn't mean that the cooking method has to be. In this instructable, we'll be wrapping onion bowls filled with butter with aluminum foil and setting them over your desired heat source - preferably a grill or fireplace; an oven will do nicely as well.
Check out all my recipes on my food blog Michael's Test Kitchen
Social media @mtestkitchen
Teacher Notes
Step 1: Ingredients
Ingredients:
2 large sweet onions
6 tablespoons butter
Pepper
Step 2: Cut Them
Cut the onions in half, and scoop out the middle so that the onion becomes like a bowl. Cut wedges through most of the onion, making sure to not cut through the bottom of the onion, which would let all the butter drain out.
Step 3: Butter It
Add the butter to the middle of the onion, and pepper if so desired. Wrap in a single solid sheet of aluminum foil to prevent butter drippings.
Step 4: Options + Enjoy!
Onions aren't picky. And there are multiple options for how to cook them.
One is to grill them. Another is to bake them. Another (the one I chose) was to put them on top of a fireplace. Your choice. Just make sure that heat is being evenly distributed, and make sure the butter doesn't drip into the fireplace - especially if it's a fake fireplace.
Either way, you can bake at 400 degrees for about an hour, or grill them for the same period of time, or fireplace them for around the same amount of time. Just make sure the onion is soft and brownish and tender.
Devour.
Barbecue Challenge
Barbecue Challenge
    • Spicy Challenge
      Spicy Challenge
    • Stone Concrete and Cement Contest
    • Games Contest
      Games Contest
    9 Discussions
    obillo
    Question 10 days ago on Step 4
    Count me in on adding bacon. Buy more important to me is this: is the foil really necessary if the onions are cooked in a skillet or oven?
    1 answer
    MichaelsTestKitchenobillo
    Answer 10 days ago
    In the oven, it would be good to have the foil completely wrapping the onion, in order to contain the butter, in my opinion; and I'm not quite sure how you'd cook an entire half an onion on a skillet completely - but if you did, I'm not sure you'd need foil for that, although you may want to cover the entire pan.
    AmieBMichaelsTestKitchen
    Reply 10 days ago
    Was hoping for a picture...I like my onions well browned and was wondering how dark they can get using this method. Guess I'll just have to try it for myself. :)
    clivegriffiths
    10 days ago
    Might be nice with garlic butter.
    MaraCreates
    5 weeks ago
    mmm... these sound so tasty, will defintely try this method of cooking onions.
