Grow Onions ... for Free!
2,603
15
About: I'm a product designer and tinkerer who loves to create.
I'll let you in on a secret, you don't need to be a green thumb for this to work. And you don't even need to be an adult. This is a great way for big and little kids to learn to grow something edible.
Supplies:
Container e.g. glass, cup, empty yogurt container - let your mind run wild. And you can decorate it with feathers, stickers, googly eyes etc.
Onion scraps: brown onion, spring onion, green onions or red onion
Something to hold the onion - toothpick, kebab skewer. I find the metal skewers work best.
Tap water
Soil or potting mix
Step 1: Perfect for Even the Worst Gardener
Ok, I don't like throwing money away. So when I buy vegetables I like to work out what I can grow from the scraps. Turns out onions and spring onions are incredibly easy to grow. Tempt them with a bowl of water and they spring (no pun intended) into action. Eventually, you will plant them in soil but the main fun is watching the creepy tentacle-like roots grow and beautiful fresh green shoots appear on top.
Step 2: Stake Night
So, you have some onion scraps, now it's time to make them into more onions.
  • Pierce a hole through the onion base, for large onions I use 2 stakes.
Step 3: Fill It Up
  • Place the staked onion on the top of a container.
  • Artist? Now's your chance to let your inner artist shine, decorate your container as you please, or don't.
  • Fill the container with water to the base of the onion. If it has roots guide them down so they dangle into the top of the water.
  • Place in a sunny spot like a windowsill.
Step 4: Change the Water
You don't like drinking dirty water and neither do your onions.
  • Change the water daily.
  • As the roots grow longer you can add less water. Only the roots need water.
  • Over the next few days, you will see the roots grow longer and new onion sprouts appearing.
Step 5: Operation
This onion is about 2 weeks old. It's looking pretty healthy and soon it will be time to transplant it into soil. I recommend waiting a few more days so the smaller green shoots are more established, but I wanted to show you the steps so I pushed on.
To do this:
  • remove the stakes.
  • gently peel off the outer layers if using a brown or red onion.
  • use a knife to separate out the different onions. The onion pictured had grown 4-5 new onions!
Step 6: Planting
  • put them in some potting mix or soil and give them a good watering.
  • onion plants should be spaced 4 to 6 inches apart in the row, with rows 1 to 2 feet apart.
  • water about once a week depending on your weather conditions.
Note: I need to buy more soil so at the moment they're in with other seedlings. But you should follow the advice above and give them space to grow.
DIY Summer Camp Contest
This is an entry in the
    • Growing Beyond Earth Maker Contest
    • Sensors Contest
      Sensors Contest
    • Planter Challenge
      Planter Challenge
    yeagerxp
    1 day ago
    I am sorry but what has grown is not onions but onion leaves, they can be eaten, no onion bulb will grow as the actual onion was picked and the final result will onion seeds no bulb, same with celery, carrots, and other similar root vegetables. Once picked the above mentioned vegetables will develop roots and leaves but not actual vegetables. I refer you to this https://www.youtube.com/watch?v=xJ2m8HHd_0I&t=1s
