Growing Mushrooms: PF Tek
554,468
381
110
Introduction: Growing Mushrooms: PF Tek
About: Twitter: @mindsforge
This instructable will go over one of the most basic grow techniques (PF Tek) for growing a wide variety of mushrooms including Shaggy Mane, Lion's Mane, and P. Cubensis.
Video of some time lapses that I've done
Step 1: Supplies to Begin
To begin growing your own mushrooms you will need the following for the PF tek:
-Pressure cooker
Check thrift stores such as savers and goodwill, also browse your local craigslist.org listings for a cheap pressure cooker, my 8 quart set me back $50, the single most expensive peice of equipment to begin growing.
-Organic brown rice flour
I found the rice flour at Sprout's grocery, any health food or organic food store should sell this.
-Vermiculite
Found at nurseries, skip the big home improvement stores
-Perlite
I found perlite at Home Depot, but this can also be picked up with the vermiculite at a nursery
-Canning jars (Ive seen 1/2 pint used alot, as well as 8oz and 250mL jars)
Safeway, but any department store, even craft stores. Be sure to use wide mouthed tapered jars! To find out why check step 11
-Spore Syringe
Can be found online, or local shops, depending on species that you wish to grow
-Aquarium/Terrarium/Large tupperware (for humidity chamber)
I found a nice medium sized aquarium for $9 at a thrift store
-Hammer and Nail
-Aluminum foil
- Alcohol lamp or lighter
Step 2: Preparing Your Jars for Spore Syringes
Spore syringes are the easiest way to get started growing mushrooms with this technique. They can be ordered online from a variety of sources.
To prepare your jars, you will need a hammer and nail.
Remove the jar lid and lay the flat lid rubber side up on a table. Take a nail and make 2 - 4 holes evenly spaced around the edge.
NOTE: In the pictures I put holes through the jar lids facing the wrong way ... with the rubber side down. The sharp edge around the hole can tear the foil in the next few steps.
Step 3: Mix the Substrate
The substrate is what the fungus will feed off of. It will consist of brown rice flour, vermiculite and water. First, take the dry ingredients and mix them in a bowl. After they are well mixed add the water.
For 12x 250mL (~8oz):
-9 cups vermiculite
-3 cups brown rice flour
-3 cups water
For my mixing bowl I halfed the amounts above and mixed only half the substrate at a time.
I have heard of adding 'worm castings' (earthworm poop) to substrate to give better flushes of mushrooms.
Step 4: Fill the Jars
Once your substrate is well mixed and moist, begin filling your prepared jars with the substrate. Don't pack the mixture down, just loosely fill the jar.
Leave about 1/2 inch of space between the substrate and the top of the jar. I just filled my jars up to the threading for the lid.
Be sure to wipe up any moisture/substrate on the 1/2" inside and outside the jar.
Fill the rest of the jar with dry vermiculite. This is to make a barrier between the substrate and contaminants in the air.
Step 5: Get Your Jars Ready for Sterilizing
Now close up all your jars, with the rubberside facing upwards (upside down from how they were designed)
Place a square of foil over the lid covering the holes and sealing the jar from contaminants in the air. Crumple it down nice and tight, forming it around the jar lid.
Put about 3 inches of water in your pressure cooker and place as many jars as you can, stacking them if you have to.
I had no problem putting jars directly on the bottom of the cooker, but I have seen people put old canning jar rings in the bottom to help prevent jars from cracking.
READ your pressure cooker's manual if you have it! It can be a dangerous tool if improperly used.
Step 6: Sterilization
Close up your cooker and put it on a stove. I used a BBQ side stove to keep heat out of the house.
Start the stove up and wait until the pressure regulator (the ball/weight on top of the cooker) starts shaking. This is around 11-15psi depending on the manufacturer.
Let the jars and substrate sterilize for about an hour.
Once the hour is up, let the cooker stand for about 3 hours to cool down, you can also sterilize in the evening and let it cool down overnight.
Step 7: Inoculation
Inoculation is the process of introducing spores of your chosing into the sterilized substrate to take hold and grow.
In this step, be sure to take precautions to prevent contamination of the jars!!
Leave the jars in the pressure cooker until you are ready to Inoculate.
It is best to use a cleaned small room (such as a bathroom), HEPA flow hood or glove box when Inoculating.
Here is the basic order of things during the Inoculation procedure:
1. Open the pressure cooker
2. Remove a jar
3. Heat the syringe needle until it is red hot, with either a lighter or alcohol lamp
4. Remove the foil
5. Insert the needle into the hole you punched with a nail earlier
6. Inject some (about 1ml or so) of the spore saturated fluid into the substrate, on the wall of the glass jar. You should be able to see the needle tip and the water run down the side of the jar.
7. Repeat with the other nail holes
8. Replace the foil and continue with the next jar, reheat the needle if it touches anything unsterilized or every 3 or so jars to prevent contaminations.
See the second picture on this step for an example of contamination, green penicillium mold is a common contaminant. Yellow and pink discoloration is another sign of contamination.
Step 8: Incubation
Now that the hard part is over, you just need to let the jars rest somewhere warm and dark. Like in a cupboard above the refridgerator, or in a cardboard box by your computer tower.
This allows the spores to incubate into mycelium the body that absorbs nutrients and water.
Keep them around 80-86 degrees F. It will just take longer for the mycelium to grow if it isn't near the optimum temperature.
It takes around 3 to 4 days to see the first hairs of mycelium forming as white spots and 3 to 5 weeks to let the fungus get to a 100% foothold in all the substrate, depending on temperature conditions.
Step 9: Science: Mycelium
Mushrooms are part of the basidiomycota phylum which reproduce using spores (basidiospores) created on the gills (basidia) of the mushroom.
Hyphae is the stringy organic material making up the mycelium. When hyphae from 2 different mycelium bodies meet they share genetic material and create a dikaryotic, secondary mycelium structure from which the fruit bodies (basidiocarps) form.
That is why we inject spores in multiple places to create more than 1 mycelium body!
The following pictures show progress of the growth.
Step 10: Fruiting Chamber
A simple fruiting chamber can be fashioned out of an aquarium or a large tupperware box.
The main purpose of the chamber is to create a high humidity (90% to 100%) environment for our mushrooms to flourish.
To easily humidify the chamber, fill a strainer with your perlite and soak it in a bowl of water for 5 to 10 minutes, drain it, and line the bottom of the container with it. This will allow the water to slowly evaporate to create high humidity.
Place squares of aluminum foil where you will be putting your substrate cakes in the next step.
Be sure to use some sort of cover to keep the humidity in the chamber. If you can drill holes into the sides of the container to allow air exchange, the mushrooms produce CO2 and require O2 to live!
Step 11: Birthing Your Cakes
Once the mycelium has taken a hold over all the substrate in the jar, the next step would be to pop the colonized cake out, or birth it.
Birthing is a fairly simple process of taking the foil and lid off the jar, flipping it upside down on a paper plate or peice of foil and giving it a few smacks downward to dislodge it.
After birthing it is a good idea to soak the cake in water for about 24 hours. Temperature shocking the fungus by soaking it in the refrigerator causes the fruits to appear quicker than a room temperature soak.
I have also seen methods that roll the cake in dry vermiculite after they have been soaked and birthed.
Remember that mushrooms are 80 to 90% water!
Step 12: Wait for Your First Flush
It takes about 2 weeks for the first flush to complete growing depending on the species.
The cakes should last for about 3 or 4 flushes, in which you may "dunk" the cakes for 24 hours between flushes to rehydrate it.
If you plan on picking the mushrooms, just grab them from the base with your forefinger and thumb and break it off at the base. They can either be cooked fresh, freeze dried or air dried for cooking later!
Good luck!
2 People Made This Project!
  • Super-Size Speed Challenge
  • Backyard Contest
    Backyard Contest
  • Exercise Speed Challenge
110 Discussions
DianeG93
DianeG93
1 year ago on Step 3
I couldn't, for the life of me, find brown rice flour. So I put brown rice in a blender - super dry - and made myself some rice flour. Worked fine.
moh93d
moh93d
Reply 16 hours ago
That's how brown rice is made!
Christmas 714
Christmas 714
2 days ago
I'm a first-time grower and I produced 4 cakes. I built a shotgun chamber and one of the cakes was doing really well. Yesterday some blacks powdery stuff I believe fell off one of the mushrooms on to the perlite. I kind of freaked out and picked all the mushrooms and put them in a drying chamber. I soaked the cake again for 12 hours and it is now back in the chamber.
can anybody tell me what it was that fell off these mushrooms?
I believe they came from Brazil and some of the caps were also starting to turn black.
I would appreciate any help I can get
verveviv
verveviv
2 years ago
I am a beginner, I followed instructions, I received spore in syringes, it was pinkish in color. I inoculated the cakes and have been waiting , I had a look a few minutes ago and the jars are still pretty quiet, however one jar has myecelium but it is a very light pinkish color - is that because it is contaminated ? - any thoughts?
cornersss
cornersss
Reply 2 months ago
Yes, pink is contamanation. Probably penicilin
Maxime1543
Maxime1543
3 years ago
Is it okay to use jars with metal lids? My local store doesn't have two parts lids
ClownW
ClownW
Reply 1 year ago
Two-player Lids are sold in every goddamn store on the planet
Maxime1543
Maxime1543
Reply 1 year ago
No they're not.
cornersss
cornersss
Reply 2 months ago
any walmart or groecery store will have them. They are commonly used to can fruit and veggies.So usually pretty easy to find
SAMP17
SAMP17
Reply 3 years ago
Its fine...sterility is the key
Straight2DVD
Straight2DVD
4 months ago on Step 8
80F-86F is a good way to promote bacterial growth. Room temperature is fine. If you're comfortable it's fine for the jars
DianeG93
DianeG93
1 year ago on Step 6
Greetings Fellow Mycologist! I only have a small pressure cooker. So, just for the heck of it, I boiled half of my jars for 2 hours. Some say an hour and a half is okay too. No difference, so I've decided to skip the pressure cooker.
MikeW404
MikeW404
Question 2 years ago on Step 12
I'm not sure about this step any more information you can give me on Flushing
MitchellP24
MitchellP24
3 years ago
Hi I was wondering, when the mycilia is growing in the substrate do you need to mist it to keep it damp?
Fieldsky
Fieldsky
3 years ago
Hi everyone,
the jars i'm using are 1 year old, and the growth of the mycelium is very different in the three jars (one is almost complete, the other two just started).
Is possible that after 1 year the water inside the jars has gone? Can I add more water now? Thanks
Jraybaybay
Jraybaybay
4 years ago
Help! I can't tell if this cake is contaminated, this is my first time trying to grow shrooms and I'm just not sure.
mklekotko
mklekotko
Reply 4 years ago
toss it quick before it contaminates the rest of the cakes
IanC114
IanC114
Reply 4 years ago
i would say so I've seen cakes like that that didnt end up making it
SHOE0007
SHOE0007
4 years ago
I forgot to mention 200 ml of tap water is added too.
