HOW TO D.I.Y a DECOR LAMP USING TAPE & BOTTLE
86
Hi friends,In this instructable I will show you How to make a home decor lamp using tape and glass bottle.This will be done at low cost ,Let see how to make one
Teacher Notes
Step 1: MATERIALS NEEDED
  • GLASS BOTTLE (I USE INK BOTTLE)
  • TAPE
  • LED BULB (OR) HALOGEN BULB
  • SCISSOR
  • POWER ADAPTER ( VOLTAGE RATING AS PER YOU BULB)
  • WIRE
  • BULB HOLDER (OPTIONAL)
  • IF YOU DON'T HAVE HOLDER THEN TAKE A SOLDER IRON
Step 2: MAKE IT
  • REMOVE LABELS FROM THE BOTTLE
  • STICK THE TAPE ON THE BOTTLE IN A MANNER,SUCH THAT YOU LEAVE SPACE TO THE LIGHT COME OUT.
  • SOLDER THE WIRE WITH BULB OR USE BULB HOLDER.
  • WIRE THE BULB WITH POWER ADAPTER
  • PUT THE BULB INSIDE BULB
  • OPERATE IT NIGHT TIME
Tape Contest
Tape Contest
Be the First to Share
    • Fashion Contest
      Fashion Contest
    • Reuse Contest
      Reuse Contest
    • Hot Glue Speed Challenge
