Introduction: HOW TO MAKE a MOCHE’S INSTALLATION
DESCRIPTION: This instructable teach how to make a libra, an hologram and a case which exalt the Moche’s Hunt.
SUPPLIES: FOR THE LIBRA
- a solid wooden prism with 6 faces in height 30 cm
- two chains in length 10 cm and in width 3 mm
- three wooden planks size 15x15 cm, 12x12 cm and 10x10 cm
- a wooden rod in length 15 cm
- a wooden plank in size 9x13 cm
- two scales with a radius of 5 cm
- a black and gold dye
- hot glue
- pieces of iron
- pieces of glass
FOR THE HOLOGRAM
- a plexiglass sheet
- a tablet
- scotch tape
FOR THE CASE
- three cardboard sheets in size 120x90 cm
TOOLS:
- laser cutter and the program inkscape
- 3d printing and programs cura and tinkercad
- drill
Step 1: PRODUCING THE LIBRA
STEP 1: DRILL THE WOODEN PRISM
Pierce the wooden prism with the drill to insert the wooden rod. The hole should be inclined.
STEP 2: DRILL THE WOODEN ROD
Pierce the wooden rod at the both ends with the drill to insert the chain in each hole.
STEP 3: HOLE THE SCALES
Do two holes in the scales to insert the extremes of the chain. The holes should be near the perimeter of the scale on the diameter.
STEP 4: ENGRAVE THE HUNT’S GOD OF MOCHE
Search the image on internet and save it in SVG.
Open the image on inkscape.
Resize it with the actual size (9x13 cm).
Modificate the file for the laser cutter.
Save the file in DXF.
Move the file of the image in the laser cutter.
Engrave the image on the wooden plank in size 9x13 cm.
STEP 5: PAINT THE WOOD
Paint the scales and the wooden plank 10x10 cm gold.
Paint the wooden prism, planks and rod black.
STEP 6: ASSEMBLE ALL THE PARTS
Glue the wooden planks 15x15cm and 10x10cm that are the base of the libra.
Glue the base below the libra and the other wooden plank 12x12cm above it.
Insert the wooden rod in the inclined hole.
Insert the chains in the holes of the wooden rod.
Glue the pieces of glass on the scale and the pieces of iron on the other one with the hot glue.
Insert the extremes of the chains in the holes of each scales and Glue it under the scales.
Glue the wooden plank of the God’s Moche in the front of the trunk of the libra.
Step 2: THE HOLOGRAM
STEP 1: CREATE THE BUILDING PLAN
Draw the construction of the 4 sides of the pyramid, isosceles trapezoids which larger base measures 18 cm and minor base measures 3 cm on inkscape.
STEP 2: CUT THE PLEXIGLASS
Move the file in the laser cutter.
Cut the plexiglass by the laser cutter to obtain the 4 sides of the pyramid.
STEP 3: GLUE THE PLEXIGLASS
Glue the 4 sides of the pyramid
STEP 4: MAKE THE HOLOGRAM VIDEO
Produce images on Adobe Illustrator to then put them in series for the video.
Set up a specific duration for the video. Save the video.
STEP 5: ACTION THE HOLOGRAM
Put the video on full screen and place the plexiglass pyramid, with the small surface down, in the middle of the screen.
Step 3: THE CASE
STEP 1: CREATE THE COLUMNS
Draw 5 rectangles for each columns in size 3x30 cm and their bases (4 circles with a radius of 3.5 cm with an rectangular hole in the middle in size 3x3.3 cm) on inkscape.
Modificate the file for the laser cutter. Save the file in DXF.
STEP 2:CUT THE CARDBOARD
Cut the cardboard by the laser cutter to obtain the pieces for the column.
STEP 3: CREATE THE CASE
Draw the construction of the case on inkscape (two rectangles in size 15 x 30 cm, two rectangles i size 30x50 cm and a rectangles 15 x 50 cm).
STEP 4: CUT THE CARDBOARD
Cut the cardboard by the laser cutter to obtain the faces of the case.
STEP 5: PAINT THE CASE
Paint the case completely black.
Paint the columns and their bases completely gold.
Glue the corners and assemble all the parts.
Step 4: THE VASE
STEP 1: CREATE THE VASE
Draw the vase on tinkercad.
Save the file.
STEP 2: PREPARE THE VASE
Resize the vase on Cura with it actual size.
Modificate the file for the 3d printing.
Save the file.
STEP 3: PRINT THE VASE
Move the vase in the 3d printing.
Print it.
Step 5: ASSEMBLE ALL THINGS
Have fun!
Made by name Sarah Michelle Biscocho, Sara Caporale, Giordano Donelli, Alessandro Ingoglia, Chiara Mistretta and Giacomo Perini, 4thB Liceo Scientifico Luigi Cremona, Milano.
Project realized during the internship at WeMake (https://www.instructables.com/member/WeMakeMilano/)in collaboration with MUDEC - Milano.
