HackerBox 0036: JumboTron
This month, HackerBox Hackers are exploring jumbo LED matrix displays, ESP32 single-chip computers, and joystick game controls. This Instructable contains information for getting started with HackerBox #0036, which can be purchased here while supplies last. Also, if you would like to receive a HackerBox like this right in your mailbox each month, please subscribe at HackerBoxes.com and join the revolution!
Topics and Learning Objectives for HackerBox 0036:
  • Configure the Arduino IDE to program the ESP32
  • Interface joystick and push-button control inputs
  • Wire data and power to JumboTron LED Panels
  • Program various applications leveraging matrix displays
HackerBoxes is the monthly subscription box service for DIY electronics and computer technology. We are hobbyists, makers, and experimenters. We are the dreamers of dreams. HACK THE PLANET!
Step 1: HackerBox 0036: Box Contents
  • P3 RGB LED Matrix with 64x32 pixels
  • ESP32 Development Board
  • Game Controller Board with Joystick
  • Power Supply Harness for LED Matrix
  • DuPont Jumpers Female-Female 20cm
  • Exclusive HackerBoxes Glider Koozie
  • Exclusive Atari retro fan art Decal
Some other things that will be helpful:
  • 5V DC power supply (2-4 Amps)
  • Soldering iron, solder, and basic soldering tools
  • Computer for running software tools
Most importantly, you will need a sense of adventure, hacker spirit, patience, and curiosity. Building and experimenting with electronics, while very rewarding, can be tricky, challenging, and even frustrating at times. The goal is progress, not perfection. When you persist and enjoy the adventure, a great deal of satisfaction can be derived from this hobby. We all enjoy learning new technology and hopefully building some cool projects. Take each step slowly, mind the details, and don't be afraid to ask for help.
There is a wealth of information for current, and prospective, members in the HackerBoxes FAQ.
The Glider is a pattern that travels across the board in Conway's Game of Life. It has been loosely adopted as an emblem to represent hacker culture since the Game of Life cellular automaton appeals to hackers and the concept of the glider was born at almost the same time as the Internet and Unix. Can you program Conway's Game of Life on the 64x32 LED Matrix?
Step 2: ESP32 and Arduino IDE
The ESP32 is a single chip computer. It is highly integrated featuring 2.4 GHz Wi-Fi and Bluetooth. The ESP32 integrates the antenna switch, RF balun, power amplifier, low noise receive amplifier, filters, and power management modules. As such, the entire solution occupies minimal Printed Circuit Board (PCB) area.
There are a few types of ESP32 Development Boards. The one used here is a variation on the "DOIT ESP32 DevKit". Most of the I/O pins are run out to the pin headers on both sides for easy interfacing. A USB interface chip and voltage regulator are integrated into the module. The ESP32 is supported within the Arduino ecosystem and IDE, which is a very quick and easy way to work with the ESP32.
The Arduino ESP32 github repository includes installation instructions for Linux, OSX, and Windows. Click to that link and follow the instructions that correspond with the operating system on your computer.
PROGRAMMING THE DEVELOPMENT BOARD
To test that the IDE is correctly configured before moving on, load the BLINK example to flash the onboard LED. Change the delay values to try different blink frequencies and make sure the code is effectively reloading onto the ESP32 board.
When programming the ESP32, press and hold-down the “BOOT” button in the ESP32 development board prior to hitting the upload button on the Arduino IDE. Once the “Connecting _ _ _ …” message appears on the Arduino IDE, you can release the “BOOT” button and programming should begin.
Step 3: Game Controller Board With Joystick
This game controller "breakout board" includes an analog joystick control and four buttons. Its size and shape are well suited for handheld operation.
The analog position control is based on two potentiometers (one for x and one for y) which are wired up in the standard "voltage divider" configuration. Accordingly, OUTX and OUTY must be read as analog values and scaled appropriately as shown in the demo code. OUTZ and the four buttons are simple on/off digital switches that normally float open and short to GND when activated.
The board can be wired to the ESP32 using DuPont Jumpers on the following pins:
ESP32  Game Controller
GND    GND
3V3    VCC
35     OUTX
34     OUTY
26     OUTZ
27     KEY1
32     KEY2
33     KEY3
25     KEY4
There is nothing special about these pin assignments, but they are the ones used in the demo code. Since certain IO pins on the ESP32 are output only, you might want to keep it simple and just use these same values.
Step 4: 64x32 RGB LED Matrix P3 Panel
With 2048 full-color RGB LEDs, this matrix is like your own personal "mini" jumbotron display. These panels are actually the same type used in jumbo LED displays as you can probably tell from the industrial strength power harness. The LEDs are positioned on a 3mm pitch grid (hence the P3 designation). They are driven with a 1:16 scan rate.
We will be using the PxMatrix Library for the Arduino IDE. Go ahead and install that library now. There is also a ton of operating theory detail at that link if you are interested to check that out.
There are three connectors on the rear of the LED Matrix Panel. These include two 16 pin dual headers (labeled IN and OUT) and also a small power header. There are three different sets of wires to connect up to these as described below.
FINE Jumpers from DATA IN to DATA OUT
IN  OUT
R2  R1
G1  R2
G2  G1
B1  G2
B2  B1
NINE Jumpers from the ESP32 to DATA IN
ESP  IN
13   R1
22   LAT
19   A
23   B
18   C
5    D
2    OE
14   CLK
GND  GND
Power Harness
The provided power harness needs to be connected to a 5VDC supply. If you plan to illuminate all the LEDs to full brightness, the panel will draw up to approximately 4A. If you have a decent "bench supply" that should be apply to provide 4A. For typical average operation, 2A might suffice. For example, we tested out a 2.5A USB power bank (battery pack), which worked fine. We soldered a USB connector in place of the screw lugs on the power harness allowing it to be plugged into the USB power bank.
There are two four-pin headers on the power harness. These are for powering two panels. One of the headers can be removed if you wish to tidy things up, just be sure to wrap up the cut wire ends (with tape or tubing) to prevent shorting the power supply.
Common Power Supply to LED Panel and ESP32
Cut one end off of a DuPont jumper. Strip and tin the wire to connect it to a red line of the harness. An easy option is to use one of the lines where we removed the extra four-pin power header. Again, be sure to wrap the power splices to prevent shorting things out. After the ESP32 is programmed and the USB cable is removed, the female DuPont plug on the other end of the spliced wire can be placed on the VIN pin (not the 3V3 pin) of the ESP32 board. This will supply power to the ESP32 board and and the LED matrix from the same 5V supply making a tight and portable configuration for running under battery power.
Step 5: Matrix Demo Prog
Program the attached jumbotrondemo.ino sketch into the ESP32.
Be sure that the PxMatrix library is installed.
The four modes of the demo program are selected using K1 - K4. The code should be fairly self explanatory for extending into your own projects.
Step 6: 1 2 3 GO!
What are you going to make with your 64x32 Color Display and Game Controller? Start brainstorming with some inspiration from other example projects...
Please send in a link to your project so we can share it with the others below:
Step 7: HACK THE PLANET
If you have enjoyed this Instructable and would like to have a cool box of hackable electronics and computer tech projects descend upon your mailbox each month, please join the revolution by surfing over to HackerBoxes.com and subscribe to receive our monthly surprise box.
Reach out and share your success in the comments below or on the HackerBoxes Facebook Page. Certainly let us know if you have any questions or need some help with anything. Thank you for being part of HackerBoxes!
12 People Made This Project!
  • Build a Tool Contest
  • Weaving Challenge
    Weaving Challenge
  • Tape Contest
    Tape Contest
59 Discussions
thealanberman
4 days ago
There's a typo in the instructions, it says "FINE Jumpers from DATA IN to DATA OUT" ... I believe it should read FIVE :)
JeffT146
Question 5 weeks ago
Is there any way to shrink the text down? I tried setTextSize, but it’s already at 1, and it only takes whole integers. It looks like some of the sample projects have text which appear smaller than the 8-pixel height in the specs?
alibabwani
2 months ago
i cant compile the code when i try to i get this message
exit status 1
Error compiling for board DOIT ESP32 DEVKIT V1.
can anyone help
i tried everything but no luck
when i compile the blink code it compiles but when i try the compiling jumbotrondemo.ino it doesn't work (i get that message )
nykr95
4 months ago
Blue LED very DIM on ESP32. Has anyone else noticed a very dim blue LED when using the Blink program?
simis69
Question 3 months ago
greetings, i get an error when i try to upload to the esp32 i get a packet header timeout. i have tried the boot button press and still have had no luck, it appears to be installed correctly. here is a copy of the log any help is much appreciated!
Arduino: 1.8.7 (Windows 10), Board: "DOIT ESP32 DEVKIT V1, 80MHz, 921600, None"
Sketch uses 188364 bytes (14%) of program storage space. Maximum is 1310720 bytes.
Global variables use 26592 bytes (8%) of dynamic memory, leaving 301088 bytes for local variables. Maximum is 327680 bytes.
C:\Users\simis\AppData\Local\Arduino15\packages\esp32\tools\esptool\2.3.1/esptool.exe --chip esp32 --port COM3 --baud 921600 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0xe000 C:\Users\simis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.0/tools/partitions/boot_app0.bin 0x1000 C:\Users\simis\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.0/tools/sdk/bin/bootloader_dio_80m.bin 0x10000 C:\Users\simis\AppData\Local\Temp\arduino_build_456074/jumbotrondemo.ino.bin 0x8000 C:\Users\simis\AppData\Local\Temp\arduino_build_456074/jumbotrondemo.ino.partitions.bin
esptool.py v2.3.1
Connecting........_____....._____....._____....._____....._____....._____....._____....._____....._____....._____
A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
*************problem was resolved with new board **********
TonyP110
3 months ago
Was anyone able to do the morphing clock with ESP-32? I can't get it to work since it was written for a different microcontroller.
gkuchera
3 months ago
Anyone know where to find the magnetic screw posts that normally come with the displays? Id like to sdd thi display to others I already have. Awesome box I look forward to playing with it more...
Psyecran
3 months ago
Great project !
TonyP110
Question 4 months ago on Step 7
What are the Power Supply options? I'd like to see how you all handled that.
Racer1TN
4 months ago
I got the raindrops program to work, it's pretty cool. Also built the Revised Morphing clock with the ESP32 12E from HB #30.
pbhoundRacer1TN
Reply 3 months ago
can you post your revised morphing clock?
Racer1TNRacer1TN
Reply 4 months ago
I fount it and another one on hackaday.io. just search by display. 64x32 led matrix. Google finds it too. Just rem out the esp8266 when you run on the esp 32 or vice versa. I'll see if I van post the link.
djcc2012Racer1TN
Reply 4 months ago
Racer1TN I cannot find the raindrops program. Is it somewhere in the exaamples? Thanks.
TonyP110
4 months ago
I am getting this compilation error. Please help:
PxMatrix LED MATRIX library_ID5437/PxMatrix.h:27:26: fatal error: Adafruit_GFX.h: No such file or directory
