Hammer Drill Switch Replacement
Introduction: Hammer Drill Switch Replacement
About: Part software developer, part maker.
In this Instructable, I will show you how you can replace the switch on any hammer drill. The drill that I replaced the switch is Parkside PBH 1100 A1 but the wiring is the same on almost any other hammer or regular electrical drill.
On this particular one, the switch was melted inside and did not turn off.
Supplies:
FA2-6/1BEK Switch - http://s.click.aliexpress.com/e/mFL6xRf6
Screwdriver set - http://s.click.aliexpress.com/e/eV82q6bO
Pliers - http://s.click.aliexpress.com/e/NSZkO3Yc
Teacher Notes
Step 1: Open the Body of the Drill
In my case, the body of the drill was held in place with several screws. After removing them, I lifted the cover to expose all of the electronics.
Step 2: Transplant the Wires
Before starting the work, I first verified that the wiring of the old and new switch are the same and then continued to transplant the wires one by one from the old to the new one.
The two main wires from the AC supply were the easiest since they are held with screws but for the rest, I had to remove the switch cover to be able to expose the pins that push the wires in.
The direction switch was the trickiest and I had to destroy it with pliers in order to gain access to the internals and release the wires.
Step 3: Assemble the Body of the Drill
After all of the wires were transferred, I did put everything back inside the enclosure and returned all of the screws.
The new switch is not 100% equivalent but since the rating is the same it should do the job well.
Step 4: Enjoy!
I hope that you managed to learn something out of this Instructable. Don't forget to check out my other Instructables and subscribe to my YouTube channel.
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Wearables Contest
      Wearables Contest
    2 Discussions
    jessyratfink
    jessyratfink
    3 months ago
    Nicely done. I'm always hesitant to crack open my tools but you make it look easy :)
    taste_the_code
    taste_the_code
    Reply 2 months ago
    Thanks! Working with mains voltage is always a bit scary but as long as everything is unplugged you should be good to go!
