Hammered Heart Pendant
851
37
Introduction: Hammered Heart Pendant
Quick disclaimer- a coworker described something she saw to me that she thought might be a fun library program, so this is my twist on something someone else saw somewhere :)
I'm mostly putting it on here because I'll be doing it in a few weeks and wanted some feedback on instructions before the program! (And related to that, this is quick public library budget, so mostly plastic beads with a few crystals. I'd suggest to practice first, but feel free to go upscale!)
Teacher Notes
Step 1: Materials
Materials:
-9” 18 ga wire
-24-36” 26 ga wire
-lots of beads!
-round nose pliers
-flat nose pliers
-wire cutters
-Hammer and anvil
Step 2:
Cut 9” 18 ga wire, fold in half slightly short of center.
Step 3:
Continue to bend wires until you have a loop. Gently curves ends of loop down into a heart shape.
If necessary, flip your heart so its longer end is coming from right and pointing left.
Step 4:
Hammer just the heart shape, *not* the tails.
(If you don't have a bench block, the flat side of a larger hammer head will work.)
Trim the longer tail to 1 ½”, make a loose spiral.
Step 5:
Wrap the shorter tail around base of heart, above the spiral.
(It’s tough to coil the 18 ga wire, you might want to use pliers to give you grip for this bit! If you have good cutters you can leave both tails long and trim after you wrap, but it's hard to nip it cleanly short with some of the cheaper cutters.)
Lightly hammer back side of spiral and fold it back and up, so it’s sitting inside the base of the heart.
Step 6:
Choose your beads! (Have lots of extras handy!)
Then cut about 24” of 26 ga wire.
Wrap one end of your wire around top of heart 3 or 4 times, right by the center loop, on whichever side you want to decorate.
Step 7:
Add your first bead, hold it against the frame, and wrap the beading wire once around the heart wire to secure it.
Keep adding beads!
Step 8:
I alternate between large and small beads, I like how they fit, but experiment!
Step 9:
When you get to the end of the side you can wrap the beading wire 3 times to trim and secure them. Squeeze the end with the needle nose pliers to make sure the ends won’t catch.
Step 10:
OR if you want to add more beads, you can wrap up around the beads back to where you started for a second layer. Wrap over your starting wrap and clip the beading wire.
Step 11:
Add a large jump ring to hang the heart from cord, or you can slide it on a chain.
Done!
Colors of the Rainbow Contest
Be the First to Share
    • Heart Contest
      Heart Contest
    • Fiber Arts Contest
      Fiber Arts Contest
    • Paper Contest
      Paper Contest
    3 Discussions
    Marthaf256
    Marthaf256
    1 year ago
    All I could say is WOW. Love the piece
    Penolopy Bulnick
    Penolopy Bulnick
    1 year ago
    These are lovely! They look like a good starter wire wrapping project too, which I really want to get into!
    magpiesmiscellany
    magpiesmiscellany
    Reply 1 year ago
    Awesome, let me know if you give it a shot! But beware wire wrapping can really start eating up your time and funds.
    Though you can fudge all three of my current projects a little, one spool of 20 ga and one spool of 26 ga isn't ideal, but as a let's try and not invest too much would work for all :)
