Introduction: Hand Carved Balsa Wood Model Siding 1:160th N-Scale
[IMG]http://i928.photobucket.com/albums/ad125/mrmartyman7/SANY0664-1.jpg[/IMG]
I put together a quick how to on the subject of how I carved the siding on Uncle Henrys Barn and how I painted the finish .
This how to is not about how to build the barn , it is about how to make the hand carved siding in N-Scale but can be
used for many different model scales.
materials :
card stock
balsa wood
tacky glue
exacta knife
sanding block
straight edge
acrylic paints -tan,gray,black,white
Blow dryer
windex
testors dullcoat
assorted artist paint brushes
heavy magnet and metal tray
1st step) trace your balsa wood on card stock.
[IMG]http://i928.photobucket.com/albums/ad125/mrmartyman7/SANY0779.jpg[/IMG]
2) run a bead of glue inside your tracing.
[IMG]http://i928.photobucket.com/albums/ad125/mrmartyman7/SANY0780.jpg[/IMG]
3) spread out the glue
[IMG]http://i928.photobucket.com/albums/ad125/mrmartyman7/SANY0782.jpg[/IMG]
4) place the balsa wood on the glue and slide to one side
[IMG]http://i928.photobucket.com/albums/ad125/mrmartyman7/SANY0783.jpg[/IMG]
5) then slide the balsa wood to the other side
[IMG]http://i928.photobucket.com/albums/ad125/mrmartyman7/SANY0784.jpg[/IMG]
6) then arrange the wood inside the tracing
[IMG]http://i928.photobucket.com/albums/ad125/mrmartyman7/SANY0785.jpg[/IMG]
7) I used my heavy magnet and metal glue up tray to apply pressure
[IMG]http://i928.photobucket.com/albums/ad125/mrmartyman7/SANY0786.jpg[/IMG]
8) I cut away the excess card stock
[IMG]http://i928.photobucket.com/albums/ad125/mrmartyman7/SANY0806.jpg[/IMG]
9) Balsa wood glued to card stock ready to carve
[IMG]http://i928.photobucket.com/albums/ad125/mrmartyman7/SANY0807.jpg[/IMG]
10) you can use a paper print out and follow the lines for scoring .
[IMG]http://i928.photobucket.com/albums/ad125/mrmartyman7/SANY0808.jpg[/IMG]
11) after the lines were scored , I used my sharp edge to scuff some detail in the boards
[IMG]http://i928.photobucket.com/albums/ad125/mrmartyman7/SANY0810.jpg[/IMG]
12) lightly sanded to remove fibers
[IMG]http://i928.photobucket.com/albums/ad125/mrmartyman7/SANY0811.jpg[/IMG]
13) painted with a coat of gray and dried with blow dryer
[IMG]http://i928.photobucket.com/albums/ad125/mrmartyman7/SANY0812.jpg[/IMG]
14) sprayed with a coat of dullcoat dried with a blowdryer
[IMG]http://i928.photobucket.com/albums/ad125/mrmartyman7/SANY0813.jpg[/IMG]
15) painted it black allowing it to soak into cracks dried with blow dryer
[IMG]http://i928.photobucket.com/albums/ad125/mrmartyman7/SANY0792.jpg[/IMG]
16) lightly sanded and brushed away dust
[IMG]http://i928.photobucket.com/albums/ad125/mrmartyman7/SANY0814.jpg[/IMG]
17) highlighted with tan, white , gray (drybrushed)
[IMG]http://i928.photobucket.com/albums/ad125/mrmartyman7/SANY0815.jpg[/IMG]
18) finished section of balsa wood siding.
[IMG]http://i928.photobucket.com/albums/ad125/mrmartyman7/SANY0816.jpg[/IMG]
the last step after high lighting would be to dry , and apply another dull coat layer and allow that to dry .
This is the method I used to build and finish Uncle Henrys Barn , every peice is scratch built on this project it is in 1:160th scale N-Scale.
I hope you enjoyed the instructable and I hope you find it useful in many of your projects.
by Marty Makarick
