Heartbeat Sensor Circuit Using LM358
About: We create simple electronic projects and tutorials easy simple cool circuit
#CircuitsDIY
PCB Prototype for $2 (Any Color):
►► https://jlcpcb.com/m
Find Full Project Description & All Useful Material Including
• Circuit Diagram / Schematic • Hardware / Component List • Codes / Algorithm • Datasheet / Pin Configuration etc
At ►► https://circuits-diy.com/heartbeat-sensor-circuit-using-lm358-electronics-projects/
For Cheap Electronic Components Visit Our Online Store
At ►► https://storeant.com
In this tutorial, we will look at How to make "Simple Heartbeat Sensor Circuit" Step by Step completely
Heartbeat Sensor is an electronic device that is used to measure the heart rate i.e. speed of the heartbeat. Monitoring body temperature, heart rate, and blood pressure are the basic things that we do in order to keep us healthy.
Teacher Notes
Step 1: Hardware Required
  • PCB Board for Heartbeat sensor
  • LM358 IC with base
  • IR LED Pair Transmitter and Reciever
  • Output Indicating LED
  • 100nf Ceramic Capacitor
  • 4.7uf Electrolytic Capacitor
  • Resistor 220 ohm 2x
  • Resistor 10k
  • Resistor 680k
  • Resistor 6.8k
  • Resistor 47k
  • 9v Battery with Clip
Step 2: Circuit Diagram
Follow all steps for making the circuit from the video tutorial above
Step 3: All Useful Material
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
