Heartbeat Sensor With Arduino, Heart Rate Monitor System
About: Share Knowledge about Arduino, ESP,GSM,Basic Electronics, DIY PROJECTS, Raspberry pi
Heartbeat Sensor is an electronic devices used to measure heart rate or speed of heartbeat. Heart rate is basically monitored in two ways -
  • To manually check pulse whether at wrist or at neck
  • By using a heartbeat sensor monitoring heart rate
Heartbeat sensor is essential for athletes as it determines conditions for heart. Although there are many other ways to measure the heart rate but the most precise is Electrocardiography. Heartbeat sensor essentially has its own importance when it comes to heart rate measurement. Heartbeat sensor comes in different shapes and sizes and even allows instant measure of heart rate.
Heartbeat sensors are available in smart watches, smart phones, chest straps and many other electronic gadgets. heartbeat rate are measured in Bpm (beats per minute). Beats per minute is defined as the number of times the heart contracts and relaxes per minute.
The heartbeat sensor has three terminals-
  • Signal
  • VCC
  • GND
Principal of Heartbeat Sensor
Heartbeat sensor works on the principle of Photoplethysmography. According to this principle, the volume of blood in an organ is measured by the change in intensity of light passing through the organ.
Supplies:
Components Required
The different components required for the construction are -
  • Arduino UNO
  • LCD display
  • 10 k-ohm potentiometer
  • Heartbeat sensor
  • Bread board
  • Jumper Wires
Teacher Notes
Step 1: Making Connections/Schematics
Make connections according to schematic -
Connect (Signal) S ===> A (Arduino)
+ VCC ==== +5V
- GND ==== - GND
Step 2: Connect Syatem to PC and Upload Code to Arduino Board
Connect the whole setup to PC and then upload code to the Arduino board for further functioning.
Step 3: Open Serial Monitor
After openning serial monitor, place any finger on the sensor except the thumb. Based on the data from the sensor Arduino calculates heart rate in Bpm
Step 4: Connect LCD Display
Connect the LCD display to the Arduino set-up. This whole set-up displays results on LCD. Make connections of LCD with Arduino according to the schematic
Step 5: Uploading New Code to Arduino
After uploading new code, place any finger on the sensor. This time the results will be displayed on the LCD.
Click here for the code
Step 6: Where to Buy?
Click here to buyHeart beat sensor
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
