Hexagon Jig
25,494
184
10
Introduction: Hexagon Jig
About: DIY Montreal is all about woodworking & DIY projects. I post how-to videos on my YouTube channel, as well as step-by-step tutorials on my website www.diymontreal.com. Builds include mainly woodshop proje...
There are several ways to cut a hexagon out of wood. You could use a table saw with a miter gauge, a band saw, miter saw, and so on. When you want to batch out several hexagons and make them all the exact same, it can get tricky. That’s why I decided to build a simple hexagon cutting jig.
Step 1: Tools & Materials
Here are the tools and materials I used for this project:
Step 2: Make a Basic Sled
I began by making a basic sled using ¾ inch Baltic birch plywood. I’m using a runner made from UHMW, which is a type of plastic. These runners are machined to fit the miter slot perfectly so I don’t have to fuss with it. Plus they won’t be affected by changes in temperature or humidity.
In the second picture shown, I’ve lined up the fence with where I want the board to sit vis-à-vis the blade. You’ll notice that the runners are shorter than the board but that’s okay for this particular sled since it won’t be moving off the front or back of the table. I’ve also skewed the sled to the left because the bulk of the jig will be on that side. Locking my fence into position I could now remove the board and drop in the runners.
Since the runners are aren’t as deep as the miter slots I’ll need to raise them up with some dimes so they’ll touch the plywood when I lay it on top.
With the runners in place, I added a few dabs of super glue then dropped the plywood into position up against the fence. Then after holding it down for a minute, I could pull off the board.
With the runners temporarily glued in place, I used a countersink bit to drill some pilot holes into the runners. I could then permanently attach the runners with some screws, making sure the screw heads were fully sunken into the runners.
Step 3: Cut the Kerf
It helps to apply some paste wax to the bottom of the sled, covering all the wood parts with a thin coat. This will really help the sled slide a lot smoother, with less friction.
After a test fit, I cut the kerf line in the sled, making sure to only go about half way, no more.
Step 4: Trace Hexagon Outline
So here’s what you need to know about a hexagon. It has 6 sides and all the outside angles are 120 degrees. I want to make one that’s 2 inches on each side.
I started by making a small notch next to the kerf line and this will just be my reference starting point. You can use any type of protractor for this, like one of those shown here. Another good option (I should have used) would be to trace the Hexagon using a the compass method (see method described in this video)
I set the protractor on the edge of the kerf line, centered with the reference mark and then marked out 120 degrees. Then I simply connected the dots.
You’ll need a few small pieces of plywood for the next part. On the first one I measured 2 inches since that’s the size of the Hexagon I want. I positioned it so the 2 inch marking lined up with the kerf line and marked off the other end. Using that mark as a starting point, I made another mark at 120 degrees.
It all makes more sense if you watch the video
Note that it can be tricky to get the angles just right, so you may need to tweak them a little bit to get the jig perfectly dialed in. If I were to build this again, I would probably actually pick up a sample hexagon ceramic tile or something that I could use as a template to get the angles and the dimensions just right.
Step 5: Secure Stops to Sled
After connecting those dots, I used my hot glue gun to secure a piece of plywood up against the line, lining up the corner with my the point of the hexagon that I traced out.
Now the other side is a little different. I’m going to start off by securing a small piece of plywood using some double sided tape so I can pull it off afterwards, again butting it up against the line I traced out.
I could then place another piece of plywood up to that one and secure it using some hot glue. Once that had dried, I could pull up the front piece.
Step 6: Why You Need a Toggle Clamp
Okay, so let me explain myself a little bit. The reason this front piece needs to be removable is for the first cut. When you start off with a square board you’ll need room to lay it down and make the cut.
That’s where this toggle clamp comes into play. I’m going to use this as a simple way to be able to easily remove the board when I don’t need it, or on the contrary lock it down when I do need it.
Step 7: How to Use the Jig
And that’s pretty much it! Well, actually I do recommend adding a back fence just to make the sled easier to maneuver.
In the video you’ll see me testing out the jig with some wood scraps, not really concerned about wastage. When using the jig it’s recommended to cut down wood blanks close to final size to limit such waste.
Other than that, you start with the block removed and make the first cut. After that put the block back into position and lock it down with the toggle clamp. Then simply rotate the blank clockwise as you work your way around.
_______________________
More from DIY Montreal:
See all my projects at diymontreal.com
Be the First to Share
    • Puzzles Speed Challenge
    • CNC Contest 2020
      CNC Contest 2020
    • Secret Compartment Challenge
    10 Discussions
    StephenC140
    StephenC140
    Reply 10 months ago
    Do you have any set up instructions? How did you figure out the distances for the stops?
    wb8nbs
    wb8nbs
    Reply 10 months ago
    Only one stop on the sled is adjustable, the angled one is fixed at 150 degrees from the fence. The blanks are cut to precise dimensions, the length is the width divided by Cosine of 30. Then on the first blank, draw in the hexagon via your method of choice, see the instructable above. Place that blank on the sled against the angled stop and do short test cuts until the kerf is right against the hexagon line. Then move the adjustable stop up to meet the corner of the blank. Flipping the adjustable stop up before the cut helps avoid the saw kicking back the cut off bit. Once it is dialed in you can make dozens of hexagons quickly.
    See https://wb8nbs.wordpress.com/2018/05/30/more-slidi...
    Great Lakes Makes
    Great Lakes Makes
    1 year ago
    Nice mod for a table saw sled. Adding a fence over the kerf will help keep the runner from binding, too.
    JavierL90
    JavierL90
    1 year ago
    Love a good jig! Imagine the cool stuff you could build with a ton of hexagons..
    seamster
    seamster
    1 year ago
    Excellent work, great results. I absolutely need to swap the wooden runners on my table saw sled to plastic ones!
    diymontreal
    diymontreal
    Reply 1 year ago
    Thank you! And I highly recommend the plastic runners. No fuss and perfect fit!
    FredG36
    FredG36
    1 year ago
    Nice set up and excellent explanation.
    Kink Jarfold
    Kink Jarfold
    1 year ago on Step 7
    Yes, this is great. I have no idea yet what I might use this for but I downloaded the plans. I'm sure something will come to me.
